Question about Radio Shack 15-2142 Remote Control
New RS 15-2142 not working
New remote. Programmed LG TV and Toshiba DVD. For each the remote accepted the code (LG TV 0856 and Toshiba DVD 1988). Remote blinked twice after each. Will not control TV or DVD. Are there other codes (The other listed code for Toshiba is 0503 is not accepted by remote)
  • slmaleski Dec 06, 2008
    I tried the codes several times to no avail. Since The remote is lighting up, blinking when a code is accepted assume the batteries are fine
  • 2,326 Answers
I would suggest to do an auto searching code and if that does not work, you can return it to the store.
The instructions on how to do search the code should be in the user's guide.
Posted on Dec 06, 2008
    President:
  • 2,110 Answers
    Sergeant:
  • 399 Answers
The code which u have inserted are proper.try doing the same procedure again.also check the battery of the new remote.remove and reinsert it again.
    Genius:
  • 3,422 Answers
HI,
Please let me know the make and model no. of your remote so that i can let you know the codes for your TV
  • Priya darshan Dec 06, 2008
    Ok.I just saw the make and model no.it is RS 15-2142
    If your device does not respond to the remote after
    trying all codes listed for your brand, or if your
    brand is not listed, try searching for your code. For
    example, to search for a code for your TV:
    1.Press TV once.
    2.Press and hold P until the red LED blinks
    twice, then release.
    3.Enter 9 9 1. The LED blinks twice.
    4.Aim the remote at the TV and press Power.
    The remote sends IR codes from its library to
    the selected device, starting with the most
    popular code first.
    5.If the TV responds, go to step 6. If the TV
    does not respond, press CH+. The remote will
    try the next code. Continue until the TV
    responds.
    NOTE: Press CH- to try the previous code.
    6.To lock in the code, press P once. The LED
    blinks twice.
    7.To search for other device codes, repeat steps
    1 to 6, substituting the appropriate device
    key
My Go Video DV 2130 remote either no longer works or cannot be programmed to my Toshiba tv. There code listed in the instruction book for Toshiba does not work. Do I need a new remote or a different...
Have the remote tested--most shops will do this for free--point the remote at the tester and press a button and tester reacts.
This can also with most digital cameras be done---in a very dark room with camera on watch its display screen and point remote and press buttons--should see some tiny flash of light on the camera display screen---cheaper to fix the remote then get another--most of the Go Video units were made by Samsung.....
Nov 05, 2012 | GoVideo DV2130 DVD Player/VCR
Will a unaversel remote work on my panasonic pv-df2704a
It depends on the remote. Some will handle combination TV/VCR/DVD units; others do not. The other issue is the age of the remote. Remote codes are limited to those for devices released 6 months or more before the remote was programmed. Since it was listed at Amazon in Feb 2004; I'd recommend a remote programmed in 2005 or later.
A guaranteed remote is available here: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12970443361250&smodel=PVDF2704&brand_pn=PANASONIC_PVDF2704 . The universal remotes that are programmed via a USB connection with a computer will be the easiest to program. I can't recommend a remote for you. I will recommend that you read the fine print for any given remote (the cheapest ones are most often not able to work with combination TV units).
I hope this helps.
Feb 07, 2011 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Lost remote. Trying to change tv input to tv video 3.
Unfortunately, you do need a remote with a TV/Video Input/Source button. http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12931505715290&smodel=32AF45&brand_pn=TOSHIBA_32AF45 has a substitute with all of the features including the TV/Video button. Any remote programmed 6 months after the TV was released will probably have a code that works with the TV. However, the lowest end ones often do not have an Input or Source button. With a remote with that button, it may take a while to find a code that matches all of the features (keep trying).
Any of the universal remotes that can be programmed via a USB connection to a computer will work with much less effort.
I hope this helps.
Dec 24, 2010 | Toshiba 32AF45 32" TV
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
I have a Toshiba TV/DVD combo model MD20Q42 and revieved it without the remote. I need to get the television to memorize all channels so I can click the channel up and down buttons but my universal remote...
One option: get a replacement original remote from remotes.com.
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=MD20Q42&uuid=12693227936230 (direct URL)
The other option is to get a higher end remote that can be programmed from your computer to match the TV's remote (but check if your tv is supported first).
I hope this helps.
Mar 03, 2009 | Toshiba MD20Q42 20" TV/DVD Combo
Does Toshiba TiVo RS-TX20 accept the digital in February?
Any DTV Converter Box.
You Need a IR cable to control the DTV Box from the Tivo.
Repeat Guided Setup and select the correct DTV Box on the setup.
Jan 03, 2009 | Toshiba RS-TX20
I have a new RS 15-2142. Followed instructions for programming a LG TV and a toshiba DVD. Remote took codes (blinked twice for each) but devices will not respond (turn on off, change channel start, play)....
I will fix it by returning the item to
Radio Shack. Do not think much ofhe service. Some guy like me makes a suggestion and then you try to up sell to another product.
Dec 06, 2008 | Radio Shack 15-2142 Remote Control
Radio Shack 15-2142 Remote Control Logo
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
