Question about Dell Latitude D510 Notebook
Motherboard resistors RV2 and RV3
Can anyone help with the values of the 2 surface mounted resistors RV2 and RV3, by the charging socket on the motherboard, please?
Unfortunately, someone attempted to replace the DC socket and dislodged these 2 resistors in the process.
  • thor918 May 11, 2010
    rustyk123, thanks for posting this!! is it 4ohm or 0.4 ohms your writing?
    do you now the purpose for the resistor rv2? I just can't understand what the point is for a small resistans there.
  • bepposchnitz
    bepposchnitz Jul 17, 2012
    RV1 and RV2 are varistor for example VZ0603M260APT and the are for circuit protection against ESD, lightning bolt, inductive load
RV1, RV2, and RV3 are capacitors. They're actually dark green in color because they're made primarily for automotive applications. If you remove one and measure it with a capacitance meter you can find the value. On a 600M/D600 I believe they're 150pF, but on other boards they may be 100pF. Digikey part numbers for them are 490-4962-1-ND for the 100pF, or 490-4767-1-ND for the 150pF. Good luck!
Posted on Aug 02, 2010
  • 50 Answers
I came across you post while trying to solve this. the rv2 might have fallen off due to design flaw. the value of rv2 is .4 ohms, just solder the two pins together and it will work perfect (better then dell's design). as for the rv3 it's value is 280k ohm this will need to be replaced.
Posted on May 29, 2009
Help ID this surface mount componant
That's a burnt resistor. I would guess that is not the only part that is bad. You have a short on the board. There is no way to read the value anymore. I'm afraid you are looking at a new motherboard. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 24, 2013 | ASUS G1SN-A1 Gaming Notebook PC
Benq LCD Tv Dv3750 PSU model FSP 320-6F01
its better if you replace the whole power supply board rather than replace the burnt surface mount parts because commonly if the surface mount parts burnt out there are some shorted parts that cause that burnt and possibly repeat the problem..
Please rate..
Aug 25, 2012 | Vizio L32 32 in. LCD HDTV
Does anyone know what value the R99 resistor is on the true sub junior
R99 on the Sunfire True Sub Junior is a surface mount resistor (no color bands), and measures 51k ohms. R102 near it is colored gray, red, brown, gold.
Jun 16, 2012 | Sunfire True Sub Jr Subwoofer
While replacing the caps on on the LCT32HA36 power supply i noticed a corroded solder joint the Z3 diode. When i attempted to re-solder it the trace came off the circuit board and I lost the R3XX surface...
The resistors are color coded.There should be 3 bands which are slightly separate from the 4th band.The 4th band is usually gold,silver,or i forget the third color which is actaually a %.The top 3 bands can tell me the value of the resistor.If you tell me all 4 colors I should be able to tell you the value,with the gold/silver/whatever as the fourth.The first one should be right near the end or top.The only 1 problem will be trying to determine the wattage rating but is usually very small within a circuit.Greg
Dec 17, 2010 | iLO LCT32HA36 Television
Dead set
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 29, 2009 | Dell Latitude D510 Notebook
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Battery not charging. Power Adapter ok
DC jack issue usually.
Or a bad repair- many techs not skilled enough will wind up losing RV1,RV2 or RV3 MOV. this is so small that I had documented it on my site. The chip has no values printed on them, and are hard to find "Close-Up"
But fear not, most of the times it is simply a DC jack replacement. They are about $8 on ebay. And only a skilled tech should replace it.
How they fail?
It is a circular tri-axial ring inside, the leaf type contacts become fatigued and no longer pick up power. Or the center contacts become fatigued.
OR the jack left the factory with insufficient solder and repeated use caused it to crack.
Don't forget to rate responses
Jul 04, 2008 | Dell Latitude D600 Notebook
Toshiba 57H82 resistor value???
When I get to work in a few hours, I will get the value for you.
Yes,you can use a regular 1/4 watt resistor and you might be
able to measure the value of it's twin in the other IC circuit....T.
Jan 21, 2008 | Toshiba 57H82 57" Rear Projection...
Dell Latitude D510 Notebook Logo
1,103 people viewed this question
Alun Cox
