Question about Cosco Alpha Omega Elite 5-Point 22-155
Removing car seat
My car seat was installed for me and I need to remove it and install it into another car. I cannot get remove it. It still needs to face the rear.
Someone told me to learn how to operate the latch system. It can be found on this site: http://www.youtube.com/watch?v=ee0lRogRO98
Some other links that were helpful:
http://www.kidsinsafeseats.ca/pdf/uas.pdf
http://www.thecarseatlady.com/vehicles/the_latch_system.html
Posted on Dec 08, 2008
How Do I Remove the 2009 Sonata GLS Rear Seat. I need to install the seat cover.
Phillip,
Replacement
Seat Assembly Replacement
1.Remove the rear seat cushion assembly.
2.Remove the rear seat back assembly.
3.Installation is the reverse of removal.
25312086-mkm0xbqveb5zta3uncrswycs-5-0.png 25312086-mkm0xbqveb5zta3uncrswycs-5-2.jpg
Dec 07, 2014 | Hyundai 2009 Sonata GLS
How do I remove the headrests in order to install seat covers?
    Remove the headrests. Then slide the cover over the seat back cushion (Photo 5). Push the bottom straps through the gap and into the buckles just like you did on the bottom cushion (refer to Photo 3). Reconnect the bib panel and pull down on the rear portion of the seat back cover to remove wrinkles.
    Spruce up Your Car: How to Install Seat Covers ' The Family ...
Oct 04, 2014 | 2012 Chrysler 200 Touring Convertible 2.4L...
What is the secret to install seat in the rear?
Lift up the rug in front of the seat to expose the bolts holding the lower seat cudhion.
Jun 21, 2014 | 2010-2011 Toyota Prius F 50/50 Bucket...
How do I remove the rear seat of a 1977 Monte Carlo?
To remove the rear seat you will need to push down and back and then pull up, this needs to be done on each side of the seat to remove it and reverse to install the seat, good luck hope this is helpful.
Nov 08, 2010 | Chevrolet Monte Carlo Cars & Trucks
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
How do i change my struts help
  1. Remove the strut assembly.
    CAUTION Do not attempt to remove the coil spring from the strut without first compressing the coil spring with the appropriate tool.
  2. Install a suitable spring compressor to the coil spring and compress the spring until the spring tension is relieved from the spring seat.
  3. Remove the thrust bearing retainer nut.
  4. Remove the thrust bearing, spring seat and dust shield.
  5. Remove the coil spring from the strut.
  6. Remove the jounce bumper from the strut.
  7. Replace the coil spring or the strut as needed.
To install:
  1. Reinstall the jounce bumper to the strut.
  2. Position the coil spring to the strut.
  3. Compress the coil spring if removed from the spring compressor.
  4. Reinstall the dust shield, spring seat and thrust bearing.
  5. The coil spring must seat in the notch of the spring seat.
  6. Reinstall the thrust bearing retainer nut. Tighten the nut to 44 ft. lbs. (59 Nm).
  7. Install the strut assembly into the
you will need a strut spring compressor which cost about 50 bucks
Jan 20, 2010 | 2002 Mercury Cougar
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Mustang rear seat removal?
please rate highly if this is what you need
Section 01-10: Seats and Tracks 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Seat Cushion, Rear Removal and Installation
  1. Release pin from locks by pressing release button under rear seat cushion.
  1. Pull rear safety belt and buckle (60044) through openings in rear seat cushion pad and frame (600A88) and remove rear seat cushion pad and frame .
  1. To install, reverse Removal procedure.
REMOVAL AND INSTALLATION Seat Back, Rear Sedan
Removal
  1. Remove rear seat cushion as outlined.
  1. Remove rear seat bolster. Refer to Section 01-05 .
  1. Remove rear seat bolster mounting bolts. Remove bolster assembly.
  2. Remove four seat back to package tray retaining bolts.
  1. Remove seat back.
May 04, 2009 | 2004 Ford Mustang
Removing rear seat back
there my be bols holding the seats in place
Aug 11, 2008 | 1988 Pontiac Sunbird
Cosco Alpha Omega Elite 5-Point 22-155 Logo
298 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
