Question about Dryers
Heat will not work in dryer cleaned vent it was ok Crosley MOD BYCD3723W2 Serial MJ5202075 Type D433-NAT-1203003-FM22
  • 3,463 Answers
I assume you have cleaned filter, look at rear of m/c and see if there is a red button, if there is, try pressing it. it may have overheated and cut out.
Other than that there are several possibilities for it not to heat, including faulty heater- faulty thermotat,-faulty timer.amongst others.
Hope this helps.
Posted on Dec 06, 2008
My kenmore dryer with serial number: DESR-NAT-1206006-FM22 doesn't have heat at all and my clothes are still wet. What to do before I call the repair guy?
Clean lint screen could be clogged a dryer sheet can sometime block the grille if a loads to large and heavy that will result in wet clothes.some dryers have an option for air dry if that is selec
Jul 24, 2015 | Kenmore Dryers
Dryer is not heating up. All cleaning of any build up has been completed. serial no: my1804125 type dwjr nat 1206006 fm22
There are multiple thermal fuses and also a thermostat and last is the heating coil itself.
Aug 19, 2013 | Ovens
My Whirlpool mod# lgb6300pwo ser # mso902052 type dwsr-nat-120606 fm22 runs without any heat. Therefore, no drying. Checked the exaust ,the gas is on . What is the next point to check?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 11, 2010 | Whirlpool Dryers
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool Dryers
Light comes on wont spin wsr-maytag mod m6d5600tqo ser mw2607338 type bwsr-nat-1206006-fm22 light wont turn off even with door closed dryer is not old new in 2008
Check the door switch. It just might be sticking which is why the light remains on and the dryer won't spin...
J. Lewis
Dec 21, 2009 | Maytag Dryers
My dryer appears to work as normal, but not heating. What could I do to fix problem on my own? Model: LGR4634EQ3, Serial: MJ0614112, Type: D433-Nat 1206006-FM22
You should unplug the machine and check the igniter to see if it shows any signs of damage. If it is damaged, replacing it should solve the problem. If it does not show damage there are a number of things it could be and it may save you money in the long run to call a techncian for service.
Dec 01, 2009 | Washing Machines
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
https://www.repairclinic.com/Shop-For-Parts/a8b6d600503/Model-11072212100-Kenmore-Dryer-Parts
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
Dryers Logo
64 people viewed this question
Top Dryers Experts
