Question about As Seen On TV Clapper Plus
Clapper plus When i plug the unit in the remote does not seem to work. I put the switch on the side to AWAY and the lights stay on. the remote does not turn them off. what does home [ho] mean and what does home [lo] mean. could it be the battery? I need the instruction manual for the clapper plus. thank you Cindy
Sliding the switch down to the HOME (LO) position will put the Clapper Plus into the low sensitivity mode. This is helpful if there is a lot of external noise in the room. By placing the switch in the HOME (HI) position it will put the Clapper Plus into the high sensitivity mode for quiet clappers or if you are far away from the Clapper. In the AWAY mode appliances will turn on with the detection of any sound but will only stay on for 10 minutes.
Posted on Jan 12, 2009
I plugged a heating system into my clapper and now it is not working. The lights on the clapper don't go on when I clap. I think it glitches out but don't know how to fix it and now I'm really upset. What...
Clappers are only designed to manage less than 500 watts. Heaters are typically much more...greater than 900 watts. You likely burned it out and will need to send it in for replacement. good luck
Feb 01, 2015 | Miscellaneous
How do I turn on without the remote control
If you have a switched outlet you can plug it into that and operate it with the wall switch. There are also many products like the "clapper" out there that work great as well.
May 18, 2014 | Dryers
Where is the programming/valet button on the antenna located
Every installer puts the valet button in there desired location under the dash, most older audiovox units had a small chrome toggle switch, some had a red push button, a lot of units had extra programming switches with cables that the installer never put in, they just threw it away after progamming, those plugged into a socket on the side of the unit, a green connector possible on older units, you need to get the model number to be specific
Feb 09, 2014 | Prestige Remote Start
When LED lights are plugged in and the clapper is off - some of the lights still glow - not as bright as when on, but still appears as if power is seeping to them (just a little). Help - really wanted to...
There's nothing wrong with your Clapper. LED's have very low current draw - under that which is required by the Clapper to function. You can add a small nightlight to your lights which will up the draw for the Clapper to work properly.
Dec 18, 2010 | As Seen On TV Clapper Plus
My Clapper Plus works fine, except that when it is off, some current still leaks through. I have Christmas tree lights plugged into it. When the Clapper Plus is off, the lights are dim, but are still on.
You obviously have a faulty Clapper. They are supposed to work just like a switch...ON or OFF. If you are getting dim lights, it is bad. Take it back where you got it or call the company.
Thanks for using Fixya.
Wayne
Dec 11, 2010 | As Seen On TV Clapper Plus
Cant open front of wall opener controll to replace Unit has large white square to open and close door plus a light and lock switch. Unit goes to lock each time we use the remote or wall...
You can insert a flathead screw driver in the side of the whote push button and pop it out. These are polarized so watch the terminals colors. Thanks BB
Jun 19, 2010 | liftmaster Chamberlain Garage Door Opener...
Radio & side mirror adjustment not working, low coolant light on
Get a hold of a schematic and a VOM and start tracing the voltages to locate and fix issue.
Mar 23, 2017 | 2001 Mazda Tribute
Clapper goes off every few minutes with no stimulus to do so
While in the Away setting, the clapper will turn on when it detects any noise over a specific threshold. After ten minutes of inactivity, it will turn off. This setting is meant as way turn on the lights as soon as you walk in the door or to startle might be intruders. If you slide the switch to Lo or Hi mode, the clapper will respond to your claps or any loud noises that sound similar. Hi is high sensitivity, for quieter rooms; Lo is low sensitivity, for louder areas.
Jan 27, 2009 | As Seen On TV Clapper Plus
Does not work
open it up. Insert an ear plug into the hole for the Mic. I got mine to respond to the distinct claps and not be confused by the noise caused by women's shoes forexample... The Radio control works by HOLDING the button for 1 sec not more. Test it with any LAMP.
Dec 27, 2008 | As Seen On TV Clapper Plus
As Seen On TV Clapper Plus Logo
1,015 people viewed this question
Top As Seen On TV Toys Experts
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Toy Expert? Answer questions, earn points and help others
