Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Wirlpool side - by side
Freezer stopped working as did the ref.. I cleaned coil and complete unit. If the compressor is bad or anyother part, is it easy to fix, check and replace? it is only 5yrs. old
  • Anonymous Apr 21, 2009
    I have the same basic problem but have checked the relay and find that there is 120VAC between the red and black wires to the compressor. The compressor is hot and the relay kicks in and out like a thermal relay that if too much current is drawn it will deenergize. I did not look further to see if there were additional wires on the back of the compressor. Wires are pretty small going to the relay, but I guess that with this small compressor it will draw probably less than 3 to 4 amps so wire size is probably sufficient. In addition to the relay, any capacitor anywhere that should be checked?----- Thanks, Paul
  • 306 Answers
There is a relay called PTC relay. It is located on the compressor. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Sometimes this relay starts a noise like clicking off and on to give you a warning. sometimes they just go out.
Let me know if you need any more help. ken
Posted on Jan 18, 2009
12 year old GE ref side by side both sides warm
has cleaning the condenser coils helped out? does the condenser have a fan? if so when the compressor is running it should be running also. is the compressor hot to touch?
May 20, 2014 | Refrigerators
Cooling quit suddenly in both freezer and fridge side. Pulled out unit and sounds like compressor is running and compressor fan (across coils) is running. Circulation fan in freezer is not running....
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Frigidaire FRS6R5EMB Side by Side...
MY REFRIGERATOR FREEZER SIDE STARTED ALLOWING FROZEN PRODUCTS TO THAW ,NOT COMPLETLY BUT ICECREAM STARTED GETTING SOFT . I MOVED APPLIANCE FROM WALL AND UNPLUGGED IT AND CLEANED FRONT OF APPLIANCE AT...
fREEZER SHOULD NOT BE BELOW 0 DEGREES. THATS OVERKILL AND EXPENSIVE.
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 29, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
40 TO 50 DEGREE IN SIDE REG/ FREEZER 32 DEGREE IN FREEZER. HOWEVER CLEANNING RESET DAILS BRING US 10-0 DEGREE FREEZER/ REF 32-38 DEGREE IN REF. THIS REF WILL NOT SABLE ITS SELF. WINTER TIME NO PROBLEM/...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Hotpoint Refrigerators
Very hot day (93F / 34C) filling freezer after shopping so door was open quite a while. Blower in freezer stops and the compressor stops running. Compressor hot to touch. Would it just be the overload...
try to clean your condenser and check the condenser fan motor if working good. then observe the unit.after u perfom cleaning try to start your ref. if the unit cannot start check ur over loador replace it if deffective. the n observe unit.or try to relocate your ref. unit may the circulation or air is not good cause of trippng of compressor. or check your breaker if ok.
Feb 05, 2011 | Refrigerators
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer part works fine, but the refrid won't cool?
The freezer is the only place that has cooling coils (condensor) the ref side steals air by way of a fan and duct from the fzr side. But in my experience the fzr i the last to go when an ref is low on freon. Also make sure the external coils are clean and the fan is running on the external side (if equip) coils are usually under the ref if it has a fan and is accessed on the bottom back by removing a cardboard access usually black. This cardboard looks flimsy but it is very important to reinstall it. It directs the air flow across the coils. after removing this you can plug your ref up to make sure the external fan kicks on with the compressor if not the fan is bad and needs to be replaced. always be careful with electricity...
Aug 08, 2010 | Hotpoint Refrigerators
GE PSC23NSD SS refrigerator malfunction
Check the cover in back of the freezer for for frost build-up. I think Frost reached the evap fan-blades and stopped it from blowing cold to the ref-side. Contro;s can be confusing. The ON-OFF controls how long the compressor runs, and the other dial how open or choked the airflow from the freezer into the refrigerator. Sometimes it happens that you have that flapper shut and no air is getting moved to the reefer. If frost is on the cover you have dead heater elements on the evap coils or a faulty hi-temp limit switch, which is the disc thingee at the top of the coils. A bad timer also may disallow it going into defrost - think about it. Chris in big bEar
Apr 20, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Fridge will not cool properly
You may have a dust build up on the condenser coil. You may notice the jam of the ref door being very warm. This is an indication of a dirty coil (located under your ref) that just needs to be cleaned or your fan motor in the back of the unit may have failed and stopped turning.
Apr 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Feb 13, 2008 | Refrigerators
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
