Question about Maytag MER5770 Electric Kitchen Range
Burner on glass stove top has turned black
Two burners on my maytag glass top stove has turned black in spots and i can't get it off seems to be in glass what can i do for the problem
  • sharonwest Jan 23, 2009
    There are black spots on the glass top stove. No amount of cleaning will get these eliminated.
  • marya579 Apr 19, 2009
    My glass top range is about three years old and it is starting to get black spots on it. They are growing by the month. Is there a fix to this?
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Posted on Apr 25, 2009
    Genius:
  • 2,920 Answers
Replace the glass top with a new one
Posted on Dec 06, 2008
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
I have a Maytag glass top range. Almost from the first use, a spot appeared on a back burner, looked like water under the glass; It has steadily grown to nearly half the burner size. On a big front...
The problem you have is most likely due to a defect in the glass top. Contact Maytag and demand a new top. The defect can cause the top to burst and cause serious injury. You should contact maytag in writing, with a copy to the United States Consumer Product Safety Commission.
Feb 10, 2011 | Maytag Kitchen Ranges
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Where can I go and get directions on how to replace the front left element on my glass top Maytag stove model #mer5750BAW. The stove top has to be lifted and the element underneth needs to be replaced or...
Good afternoon. We are Maytag factory authorized service and parts suppliers and have all the solutions for your Maytag appliance issues.
We have the proper element for this model and can get it out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST and we will get your parts out right away.
We look forward to hearing from you. Thanks, Ella
Jan 15, 2010 | Maytag MER5750 Electric Kitchen Range
Black spot on glasstop Kenmore stove
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Cooktops
Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
Apr 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
MAYTAG Model ME5770AAW Ceran Top Stove
the lights come on but the burners will not heat up what would be the issue
May 31, 2008 | Maytag MER5775Q Electric Kitchen Range
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
Maytag MER5770 Electric Kitchen Range Logo
1,725 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
