Question about Canon PIXMA iP4000 InkJet Photo Printer
Canon ip4000 - green power LED indicator flashing orange,
Says cancel all printing, turn of then turn back on, should be ok - but isnt - error code 6800 coming up - What does this mean? - Frank Summers
    President:
  • 2,110 Answers
Logic board ***'y (QM2-1548 is needs to be replaced...
Posted on Dec 06, 2008
  • ise piq Apr 01, 2011
    This is how I just fixed a Canon MP800 all in one with the flashing green & orange lights (a series of 9) & error code 6800. Left it UNplugged from the electrical outlet over night(You have to give it HOURS UNplugged or this will not work). Plugged it in the next day & turned it on. First window now showed a different error iu30 or some such, & showed a graphic of the ink cartridges with problems recognizing them. Held down the RESET button until the graphic showed the first cartridge as ok, (the picture will change), let go and held down the RESET button again for the next cartridge & so on until all 5 were ok. The screen then changed to a menu asking me what language I would like. Used the arrow keys around the OK button to select English. Then pressed OK for that language. The screen then changed again & said it would have to do a printhead alignment & to put paper in the printer. I put paper in & pressed the OK button again. It took about 5 minutes for the print head alignment. The paper with the alingment marks came out printed correctly. The next screen showed a normal screen which usually defaults to the Copy properties. Turned the printer off & on again a few times & everything was fine. Have no idea how long this will last or what caused the problem, but it is fixed for now. Related Problems & Solutions Filter Problems by Issues:
Error Code no. E000067-0110
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
  2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
  6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
If the issue still persist contact manufacturer
Jul 06, 2011 | Canon iRC3100 Printer
My Canon Pixma IP400 is not working and the orange light is flashing 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release theresume/Cancel button. (DO NOT release the Power
button.)
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma ip4200 flashes orane 5 times
While holding the Power button, release the resume/Cancel button. (DO NOT release the Power
button.)
time(s) setting).
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Waste ink absorber - what is it and how do we rep[lace it?
plz try
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
5 times Orange (Alarm) Destination settings [hth: not applicable]
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Note : if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work.
Aug 26, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon ip90 does not print, continue to get 5100 error msg
you can try this method to reset the error..
First close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.), then while holding the Power button, release the Resume/Cancel button but do not release the Power button.
While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange. During initialization, the LED blinks in green. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. Pls note each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.
Then press the Power button, the LED lights in green, and the
selected function is performed. When the operation completes, the printer returns to the menu selection mode automatically. Last just power off then back on and test.
May 28, 2010 | Canon PIXMA iP90 InkJet Printer
I have a Canon Pixma IP 4000 and keep getting the error message that the ink absorber is nearly full. Print quality is not good even after cleaning. What should I do?
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma mp-610
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 19, 2009 | Office Equipment & Supplies
Error 5100 canon ip90
You may try this to rest the 5100 error:
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Dec 07, 2008 | Canon PIXMA iP90 InkJet Printer
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
selectable.)
button.)
Power
in
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
in servicing.
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Ip4000 5 flashing orange lights
5 orange flashes indicates a problem with the print head. you could try carefully removing the print head (the thing holding the print cartridges) and replacing it. turning it off/on. make sure the print cartidges are ok. If still no good you might need to get it serviced?
Aug 24, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
330 people viewed this question
old marine
old marine
