Question about Philips 20PT6441 20" TV
No TV Signal
TV does not receive regular TV signal, but plays DVD perfectly. Tried auto programming, but received neither TV picture nor sound. Connected another TV to the cable connection hooked to the TV, but received signal.
  • Philips Master
  • 5,568 Answers
This is an older message but if you haven't thrown the set out yet, don't!  Later flat panel sets don't seem to last longer than a year or two before failing so you might want to keep this one.
Your set's tuner has failed. This may be a separately replaceable module.
If you want to take a stab at it, unplug the set for at least several hours, remove the few screws (less than 10) that hold the rear housing.
If the tuner section is not integrated into the main board, you should see a device that is shielded by a sheet metal housing in which the tuner resides.
If this is obviously removable, look on line for a replacement unit for your model of set. They may or may not be still available.
If you can't identify the tuner check with the BBB in your area for a surviving TV repair with a good reputation.
Posted on Jan 10, 2009
Fix tv picture
If the TV is receiving its signal from a cable TV box or DVR then you need to find out if the problem is in the TV or the cable box/DVR. Connect a different source to your TV such as a DVD or Blu-ray player and play a DVD movie. If the problem occurs again it suggests the TV needs repair. If the TV works OK when playing a DVD movie then that suggests that your cable box/DVR needs repair or replacement.
If your TV is receiving its signal directly from an antenna or cable outlet on the wall then you should try replacing the cable wire from the wall to the TV with a new wire. If that doesn't help then your TV probably needs repair or replacement.
Dec 29, 2015 | Sanyo Televison & Video
I am have my DVD player connected to the receiver via component cables (blue, green, red). Sound is playing perfectly via its own set of cables. I have an HDMI leaving the receiver as an input to the...
Sounds like your receiver only supports HDMI "pass-through"
HDMI passthrough will only forward the video signals from the source HDMI port, it will not actively convert the Component Signal to HDMI.
May 30, 2011 | Yamaha RX-V663 Receiver
No Signals
You may have to access the initial setup menu to force the set to look at the cable input. Although that is typically the default today, it may be looking for signals from an antenna. Broadcast and cable use different frequency ranges so the set has to be able to see the range you are trying to watch.
Dec 06, 2008 | Philips 20PT6441 20" TV
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Unusable Signal
I have exactly the same problem, with my RCA F27645. I can find no answers on the internet, so far.
I have 3 ideas.
1) The digital signal receiver must not be receiving the DVD signal properly.
2) Coaxial cable receiver (the little pin plug) problem
3) Digital TV (broadcasts) causing havoc on older TVs.
Mar 27, 2008 | RCA 27V530T 27" TV
No Audio coming from DVD source
Press the input select button on front of receiver until auto is displayed it may be set for analog. Auto mode will play digital signal first then if it does not see a digital input it will check for analog signal. I would set it to auto for all inputs you may use.
Jan 10, 2008 | Denon AVR588 Receiver
No Picture
check the power cord
Dec 17, 2007 | Sony KV-32S42 32" TV
Can't view picture, but can hear sound
Are you trying to record TV signal onto a DVD, or are you playing back? What make & model is your TV and DVD player/recorder?
Oct 22, 2007 | Yamaha RX-V620 Receiver
Philips 20PT6441 20" TV Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
