Question about Epson Stylus CX6600 All-In-One InkJet Printer
Printer My printer has new ink cartridges. I have tried the nozzle check and head cleanining. I have tried everything my quick guide has suggested. When I try to copy or print, I get a blank sheet. Hope you can help me. Thank you Darlene
  • Gammm Dec 11, 2007
    Printer is producing blank pages when printing or copying. Tried head cleaning several times...still blank pages. Any suggestions?? Epson CX 6600 All in One. Thank you!
  • Epson Master
  • 691 Answers
Hey Cinders! It sounds like you have clogged plumbing. The pipes to the waste ink tank can get clogged as can the wick (the bit that sticks up in the ink cartridge) Get in touch with the good people at http://www.TheServiceManualShop.com and ask them for information on the CX loss of ink rescue kit.
Posted on Apr 12, 2007
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
HORIZONTAL PINK LINES
The nozzle check pattern should be complete, no gaps and breaks on the lines. Try to turn of highspeed printing, It is on the advanced tab of the printer properties window.
Apr 23, 2010 | Epson CX8400 All-In-One InkJet Printer
Epson PictureMate - can't clean all nozzles & Error P
Many times head cleaning will throw much ink away. 1 time about 10% of ink. After meny times head cleaning, ink will out, and need replacement. May be after head cleaning nozzle is ok, but after replacement, printer do ink charge. It may be distrub the flow of ink at head. Is the cartridge new?. Use CISS for continuity printing.
Jul 26, 2009 | Epson PictureMate C11C623001 Photo Printer
I replaced the ink cartridges on my Epson C40UX and after several cleans and nozzle checks only the blue and yellow inks are coming out
I presume your printer was printing all colours before the cartridge change. If you removed the old cartridges a few hours or more before you fitted the new ones, it is very likely you have nozzles clogged with dried ink. If this is the case, do a head soak as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you now get any of the missing colours on the nozzle check, then there is hope! Try 2 or 3 more head cleans (but no more). If still not a full print, repeat the soak process until you get a full nozzle check.
If the new cartridges went in immediately after the old ones came out, it is unlikely to be blocked nozzles. If you changed the cartridges without using the proper procedure with an ink charging cycle, you may well have got air into the nozzles. This just takes patience - try a daily head clean to see if the ink gradually appears.
Finally, you may have faulty or out-of-date (dried-out) cartridges. The easiest way to check this is to try new cartridges in the nozzles that don't print, making sure you use the proper cartridge exchange procedure. Compatible cartridges are very cheap on ebay - £3 a set in the UK.
Please come back with further information on what you have tried if none of this helps.
May 16, 2009 | Epson Stylus C40UX InkJet Printer
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
JUST REPLACED INK CARTRIDGES ANDPRINTING IS JUST NOT RIGHT.
To carry out a nozzle check turn the printer off, then press and hold the Ink (looks like a droplet) button and the Power on button for about 3 seconds. The printer will turn on and print a test pattern. It also shows how much ink is left in each cart. All the lines should be continuous in each colour, any gaps mean that the print head nozzles need cleaning. To clean the nozzles press & hold the ink button for 3 seconds. If badly clogged it may require four or five cleans, leave for about ten hours and do another set of cleans. If still clogged you may need to purchase a print head cleaning solution such as can be found here:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
To carry out a head alignment download the quick guide and users manual from the Epson site:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58606&prodoid=56291067
Hope this helps, please take a moment to rate this solution, thanks.
Mar 20, 2009 | Epson Stylus CX4800 All-In-One InkJet...
No text
Check that your black ink cartridge has ink inside, eventually try a new cartridge , as ink may have dried up in old cartridge.
If you use a new cartridge ensure you removed cellotape from cartrige.
If cartridge is ok, then it is printer nozzle/head for black ink.
In this case do nozzle check / head cleaning in printer tools a couple of times.
If problem persist you may need to check and clean printer's head with cotton and solvent.
regards
Mar 20, 2008 | Computers & Internet
Epson Stylus CX6600 All-In-One InkJet Printer Logo
157 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
