Question about GE WDSR2080D Top Load Washer
Floods overflow tube when pressure hose plugs at outer tub
Have seen this problem on more than one unit, do not have model handy, not very old, less than 5 years, otherwise working ok.........
Does GE have any type of repair or replacement tub of different design to prevent this problem permanently without just clearing and or replacing pressure hose and having problem again down the road?
  • 1,543 Answers
I usually see this problem from people who rarely or never use liquid bleach. To prevent recurrence, fill washer to lowest water level, hottest water, with several cups of liquid bleach, and run a complete cycle with no clothes. Do this once every couple months if you are in an area of the country with water conditions which seem to encourage the formation of the gunk that clogs that water level tube you mentioned. Sometimes switching to a different type or soap, fabric softener, or reducing the amounts of those will also help greatly. This should be a FixYa for your problem.
Posted on Dec 06, 2008
Water keeps filling and overflowing when turned on but will stop when turned off, how can I fix this?
Could be a faulty fill switch. The fill switch is often an air pressure switch. As the tub fills a small internal air pressure is created which is sent to the switch via a small hose that sometimes becomes blocked or displaced.
If not it is possibly a fault with the control board.
Aug 01, 2016 | Washing Machines
The water fill is very slow
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
May 27, 2015 | Hoover Washing Machines
Washer flooding!
Washer fills with water and overflows:
May 07, 2014 | Estate Washing Machines
The whirlpool washer overflowed and flooded the apartment
Need new pressureswitch or the pressure switch tube is not connected to tub or pressure switch itself!!! where it connects to tub at airdome might be plugged with dirt,soap ect!!!
Mar 15, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Have a hotpoint top loading that A..would not stop filling even unplugged, and B. will not drain/spin. Hence, ended up with a flooded room while I was trying to get the water turned off. Any easy way to...
Hi
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
When it doesnt spin or drain...
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting fixya.com
Nov 02, 2009 | Washing Machines
The water will not shut off after filling up the washing machine and floods the wash room
Sand or trash in the air line going up to the water level switch. Blow out that tube and connect it back secure. Pump out any water in the tub at the time of the fix and retry on low level.Look at this diagram: water%20level%20operation.jpg As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed!
Oct 25, 2009 | Kenmore 22422 Top Load Washer
The water keeps running and overflows the tub
Check for a faulty water level/pressure switch. This is a diaphragm like device with a small plastic tube (which you were blowing into) attached between the switch and the bottom of the washer's outer tub. As the water level rises, so does the pressure on the air in the plastic tube and when it reaches a certain leve it activates the switch to shut off the water. Make sure there is no obstruction in the tube and that it is not damaged in any way. The switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will mean a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Oct 15, 2009 | GE WBSR3140DW Top Load Washer
I have a kenmore model 110 and it is overfilling the water doesn't stop and it overflows, flooding my basement.
Pull the top of your washer off, look on the tub and you will see a round plastic reservoir. You will see a plastic tube come out and to to the control panel. Make sure that hose is attached at the tub and the pressure sensor.
Sep 13, 2009 | Washing Machines
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
GE WDSR2080D Top Load Washer Logo
181 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
