Question about Philips 20PT6441 20" TV
No Signals TV does not receive regular TV signals, but DVD images shows clearly. The cable connection is checked okay and even confirmed by connecting another TV to the cable connection. Auto programming does not show TV pictures or sound, only DVD picture and sound is okay.
  • Philips Master
  • 5,568 Answers
You may have to access the initial setup menu to force the set to look at the cable input. Although that is typically the default today, it may be looking for signals from an antenna. Broadcast and cable use different frequency ranges so the set has to be able to see the range you are trying to watch.
Posted on Dec 06, 2008
My picture is blurry,and words are blurry,what do i do
A blurry image on a high-definition LCD TV is typically the result of a mismatch between the TV's resolution capabilities and the resolution of the signal that is coming from connected devices, such as a DVD player or satellite TV receiver. Typically, blurry pictures result when a peripheral device connects to the TV through nonHD cables and jacks.
If your TV's connected devices do not have HD capability, they will transmit content to the TV in standard, analog signals. These types of signals are only capable of resolutions of up to 640 by 480 pixels. Pixels, for picture elements, are the tiny dots that make up the screen image. Most HD LCD TVs are capable of resolutions of as low as 1,366 by 768 pixels and as high as 1,920 by 1,080 pixels. When this big of a discrepancy occurs, the images display on the TV scaled, stretched and blurry.
Jan 24, 2015 | Televison & Video
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
The screen shows a green/ orange screen, even when we play a DVD... How can we make that go away?
How is the player connected to the TV? It could be S-Video, HDMI, RCA, or Component Video cables. My guess is that you're using component video cables. There will be three wires that carry the video signal to the TV, and each wire carries one color. There will be a blue, yellow, and green cables. If one of these cables is not seated properly, it can cause only one or two of the three color signals to make it to the TV, causing the image to be discolored. You should check the connections of the cables. You'll also see the sound cables, probably red and white. Do not get the red video and the red sound cable mixed up!
Jan 16, 2011 | Philips DVP3982 DVD Player
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
Signals to the tv from other sources and the image is P and G
Soon as though you have your wiring mixed up. Those leads, colors you describe are for Compnent Video signal....Red Green Blue. Now  the Others  are for Audio Visual signal , Yellow, Red, White... They are NOT compatable. IE: You cannot mix them. Check in your manual as to what  types of lead is needed how to wire it up..
Feb 01, 2010 | Televison & Video
I'm confused about HD (high definition) and digital
In Australia analogue TV signals will be phased out and finished by the end of 2009 (I think).
If you have a standard analogue TV you won't be able to receive any more free to air analogue TV programs when they stop brocasting these TV signals. To recieve the new digital signals you need to buy a digital set top box (which receives digital TV signals and converts it to analogue signal that can be displayed on your old TV). The set top box will only receive Standard Definition signals and this is a lower screen resolution that is available from High Definition signals.
Digital TV signals offer approx. 15 TV channels ln High definition and Standard Definition, different programs channels will be available from the same TV broadcaster, although the High Definition pograms will also be repeated on one of the Standard Definition channels.
High Definition gives a sharper image than Standard dedinition, but you may not notice much difference because it depends much on the material you are viewing, You will notice how clear DVD and BlueRay movies are compared with the VCR tapes. To get the best images from DVD movies your player must be connected to the HDMI connector on your High Definition TV (provided your DVD player has one, usually BlueRay players will have one, they also will play normal DVD disks).
If you purchase a new High Definition TV you will also be able to receive all the Digital TV programs. Currrently these TVs are avail in Plasma or LCD screens and there are newer technologies within a few years. The Plasma screens use twice as much energy (electricity) as a LCD screen. It is suggested that the viewing distance to the TV should be 3.5 times the size of the TV screen.
Hope this answers your query.
Get back to me if you have any more questions.
Mar 03, 2009 | RCA TruFlat 27F520T 27" TV
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
Just bought TV and connected with red,white, yellow and s-video connections. screen says NO SIGNAL. I have a satellite dish and dvd/vcr. the dvd/vcr image shows up on tv screen.
* Possible Problem *
It's not clear how you have each of the components connected to the TV, but you do mention that you used the "yellow" and s-video connections. Those are both video connections. The yellow is a "composite video" connection. Many TVs won't accept signals from both the yellow and the s-video connections at the same time. Usually one will override the other.
* Possible Solution *
Make sure the satellite dish is on and (hopefully) on a valid channel. Try disconnecting the s-video and checking the screen. If it didn't work, remove the yellow connection and replace the s-video cable. Check again.
If the problem persists, please explain how the TV, dish and the dvd/vcr devices are connected to each other (audio cables not relevant).
May 15, 2008 | Televison & Video
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Philips 20PT6441 20" TV Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
