Question about JVC Televison & Video
How do i clean the mirrors on a big screen tv
  • 505 Answers
In most cases you can remove the back of the TV and get up inside the cabinet to clean the mirror. Windex works great on any glass mirror, but if it is mylar, a less harsh cleaner is better. If you have a newer digital type projection, you will likely have to go in through the screen to get to the mirror and it is much more difficult. I can instruct more depending on type and model of tv.
Posted on Dec 06, 2008
4 Suggested Answers
SOURCE: How do I clean the
you have to pull the staples on the back
Posted on Jul 25, 2008
SOURCE: Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Posted on Sep 16, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: How do you clean the mirror?
It's been a while since I faced one of these, but I believe the bezel around the screen pulls off to expose the screen mounting screws. As I recall it is held on by snap fasteners. It's also possible there is a snap-on trim strip between the screen bottom edge and the speaker grille. If that's the case, remove that to expose screws securing the bottom of the screen. Once they're out the screen swings up and off. Zenith used a couple of methods on different models.
Posted on Nov 27, 2008
I have a magnavox big screen tv the picture is pretty dull. I was wondering how i can fix that problem
First try cleaning the mirror and the tops of the picture tubes. If this doesn't help, you'll probably have to change out the CRT coolant.
good luck
Sep 02, 2009 | Televison & Video
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
I need to clean my 1997,52 inch rca tv screen
OK
Take the screws out of the BACK top panal of tv! be gentle the mirror is connected to this back!.... now after removeing back you will see the inside of screen and the three lenses and on back panel the mirror! clean all three of these and you will see a big change for the better..Then just replace back! (The screen itself does not come out!)
Please take a second to place a rating for my answer!
thank you!
Jan 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Cobwebs behind the screen of a Mitisubishi WT-55809
Wile your in there you might as well clean the mirror and the lenses *and you will see a big change in your picture!
Remove screws from upper back of tv to access this area ..be carefull with the back the mirror is connected to it!Please rate this answer
Thank You!
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Bog and dust on mirror....showing up on screen, how best to clean?
remove pointy screws out of back of screen ( 3 up each side and 4 across top). remove speaker grill, remove 4 screws from center cover. remove 4 screws from bottom of tv, disconnect wire bundle. lift screen up and off. clean mirror facing up and lens. Do NOT touch big mirrror, trust me. put it back together by sliding screen back on and making sure all edges are flush before putting screws back in. the pointy ones go in the back every other screw is flat. good luck, should only take about 5 minutes.
Dec 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have A pioneer sd-p4571 projection big screen tv and the picture is cloudy how do i fix it
remove the screen assembly and clean the lenses the mirror, and the back of the screen. What you have is dust on the inside.
Sep 29, 2008 | Televison & Video
My Mits-Projection TV model WD-52825/WD-62825
Good Day, jmkay;
I see no reason why you can't do this yourself, but unlike the pioneer you have to approach the Mit's from the back and will have to remove the back from the screen (sort of)....charge you battery and Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mar 31, 2008 | Televison & Video
Dull picture
Yes you can take the back bottom of the tv off.You will see 3 bulbs 5or6" in diameter.take a very soft clean cloth spray cloth not bulbs.windex persoal cleaner for your glasses ect.wipe bulbs gently removing dust.Above thes lights are the mirror maybe 10"by12" clean that to spray cloth not mirror than wipe clean"Now get limber and try to reach the inside of the big screen and wipe completely.
Dec 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
296 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
