Question about Belling BE808 Compact Refrigerator
Tenant says fridge is not cold enough and that food has gone off
Hello
We have a Belling Larder fridge (integrated compact) in the kitchen of our rented house. Whilst we were decorating there, we kept milk and a few little bits of food in it without any problems (full fat milk was ok after a week). Since then a Tenant has moved in & has claimed it is not working correctly as it is not cold enough. The settings are 1-7, which she keeps turning down to 4. We have put in a fridge thermometer which is reading 6.c this should idealy be up to 5.c max. When placing the thermometer, we turned setting up to 5/6, however before we had a chance to assess, she had turned it back to 4. Before we spend £200 on a new fridge - is it reasonable to expect her to turn it up and if she does, is it likely to correct the problem? Thanks for your help.
    Sergeant:
  • 302 Answers
I would check to see if the heater is working? It would behind the plastic back wall of the freezer. if its all frozen up and ice all over, get a hair dryer and melt ice and get a new heating element. cost is about 50 dollars
Posted on Dec 06, 2008
I AM LOOKING TO PRICE A BELLING BUILT IN FRIDGE FREEZER
Michael, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cooling
Belling Integrated 70 30 Fridge Freezer
Buy Belling BIFF233 Integrated 70 30 Frost Free Fridge Freezer from...
http://www.powercity.ie/?par=45-25-BFF233
Mar 12, 2016 | Belling Refrigerators
My larder fridge sr5045 frosts at top but dosent get cold enough
low on freon, freezing up no cooling, probably just has enough in it to cool your fridge.....
Aug 02, 2013 | Refrigerators
Fridge is not getting cold even though the thermostat is at 5
Most friges take cool air from the freezer with a fan to cool the rest of the unit. I am not familar with your model but there should be a fan somewere in the back of your freezer. Also make sure you have space in back and to the sides of the fridge for air flow.
Jul 24, 2013 | Tecnik Built Under Larder Compact...
My larder fridge keep's freezing up on the (R) hand side
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 18, 2011 | Refrigerators
During heavy frost everything froze solid even drainage pipe. I notice that my freezer (top half) is not cooling at all. All food has gone soggy. Fridge is just cool.Will it right itself once kitchen...
It's possible the unit is not working correctly as it expects the air temperature to be around 18 degrees centigrade. If too cold, they can go into a defrost cycle.
If your food is not cold enough - but your room is frozen - can you pack your freezer items in snow? Alternatively, move the unit to a warmer area.
Sounds strange - but modern units don't work well in the cold !
Dec 25, 2010 | Refrigerators
The cooling unit stops running periodically.....long enough to allow food in the freezer to thaw. The fridge light is on, so electricity is getting to the fridge. The previous tenant had dogs, and when we...
Could be defrost sticking or the compressor not starting...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Belling Bi60 Integrated fridge freezer (fridge) not working
I also have probs with Belling Bi 60 less than 3 yrs old...already had
enginneer out & paid......now fridge aint cooling showing H
its frost free and this may be too sensitive ??
tried unplugging no Go
wont buy Belling again
Dec 15, 2008 | Refrigerators
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
Oct 06, 2008 | Belling Freezers
Belling BE808 Compact Refrigerator Logo
267 people viewed this question
Top Belling Refrigerators Experts
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
Nater13
Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
