Question about HP Officejet 7210 All-In-One InkJet Printer
HP Officejet 7210:White hazy line on right side of scanning glass
Is it possible to disassemble the top of the scanning plate to clean the underside of the scanning glass on an HP Officejet 7210?
  • dale941 Dec 11, 2008
    It appears to be an accumulation of dust that I can't possibly get to through normal cleaning methods. Dust can get anywhere if there is not an airtight seal, which seems to be the case here. The line of dust is close to where the scanning bulb's resting position is.
    Guru:
  • 449 Answers
You will have to take the whole thing apart my advice to you don't try it, if you do the scanner can go bad. I'm just trying to help good luck
Posted on Dec 19, 2008
  • 153 Answers
U can unscrew the parts and clean it but must be very careful in  dismandling
be sure lens is kept proper and be safe
    Sergeant:
    Novelist:
  • 327 Answers
Yes it is very much possible to open the scanner unit and clean the underglas.just have to open the screws and plastic locks.must have proper screwdriver.
Like many other people I have a vertical line down the copy, using the document feeder, not the plate glass. on my HP officejet J5780 3 in one. Your advice is to clean the small glass plate. I look...
I dont have a picture at the moment but if you lift the document feeder up to expose the large plate glass, the small plate glass is normally situated at the extreme left hand side of the large plate glass.
May 29, 2011 | HP Officejet J5780 All-In-One InkJet...
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
Vertical line appear on my HP OfficeJet J 6450
Look at the narrow glass and see if there's white out or anything on it, also the white reference guide above the glass needs to be clean as well. The skinny glass under the adf is where documents are scanned when not placed on the big glass.
Jul 31, 2009 | Office Equipment & Supplies
Lines on my copies
As the page you wish to copy goes through the document feeder, it passes the scanner as well as a white plastic band that the scanner "compares" the dark writing or data on the page to. If this white plastic band is not very clean, the scanner reads the dirt as if it is part of the image you are scanning. Try cleaning the band as thoroughly as possible, as well as the small piece of glass to the left of the larger glass on the flat bed scanner. Make another copy to test your results.
Hope this helps!
May 07, 2009 | HP LaserJet M5025 MFP All-In-One Printer
Black lines on copies and scans
HP Support may have a history of this problem w/this printer.
Apr 29, 2009 | HP 7210 OfficeJet All-In-One Printer
Cleaning underside glas plate
Hi, I had to dismantle my HPG55 to clean the glass and found the instructions at the HP website. The link to the site is below. The instructions are very clear, and there are also photos to help you along the way. I hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=de&dlc=de&cc=de&docname=c00498704#N216
Sincerely,
Tosty
Feb 23, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
My church has a HP Color Laser Jet 2840 someone came into the office and evidently pressed the scan button. The screen reads "Scanner error 5 turn off then on." I did this several times but it...
clean the glass, and if possible clean the underside.
At startup the scanner tries to define white. If you open the top and clean the under/otherside of the glass, you will see a strip of white labeling about 1/4" wide by the length of the scan area, this is the default white that the scanner uses to calibrate. Over time it gets dirty or spider webs get on it, clean it, but don't spray anything directly on it. Reassemble the top and power up.
Jan 02, 2018 | HP Office Equipment & Supplies
Black line when scanning or copying from top feeder
Please check whether their is any thing on the glass of the scanner or there might be some dust or something might be stuck the glass that's why this problem occurs. so kindly clean the scanner glass with neat and clean cotton with some spirit on it and this will help you resolve your problem.
Dec 04, 2008 | HP Officejet 7210 All-In-One InkJet...
White line down side of page when scanning
I chatted with HP and they told me to clean the ADF frame which had some dust particles on it. Problem solved.
Jul 23, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Hp officejet 4355 scanner problem
don't on prints..super clean scan glass, slit of glass where originals are fed.
Nov 21, 2007 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
44 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
