Question about HP Office Equipment & Supplies
Printer is not responding. Prior to this, printer was not fully ejecting a printed document. Unfortunately, I pulled the last document from the front. Since then, there is no response from the printer when trying to print a document. My printer is a Photosmart 2710 All-in-One.
  • rolyac Dec 06, 2008
    My computer is an iMac OS X 10.4.11
  • rolyac Dec 10, 2008
    Printer, although slow, did print and eject a printed document after following you suggested solution.  However, when printing a page containing a photo print the image was not sharp and was actually cropped.  Please help.
    Thanks,
    rolyac
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
The printer usually lets you access a hard copy prints of any documents by interacting with the user's computer. It further helps us in generating hard copies of all types of documents that are existing in an electronic form in our computer's hard drive.
Steps to troubleshoot Canon PIXMA Error "Printer Not Responding" Issue
Step 1: Check for cables and connectors
·If you are stuck under the error known as "printer stops responding" then, the very first steps for you is to ensure that you have properly connected all cables as well as connectors that are primarily used to connect all printers with your computer devices.
Step 2: Check for any malfunctioning cables
·Now, the next process is to perform a thorough check for any malfunctioned cables as well as connectors that are a wide cause of trouble.
Step 3: Ensure that all ports are well connected
    ·Do ensure that all your ports are well connected to the printer as well as to the computer.
    ·Well, be careful while installing your printer and check whether it is installed in an accurate position or not.
    ·If it is not connected to accurate ports then, you need to connect the printer in the correct port.
    Step 4: Check for compatibility issues
      ·Now at last, you need to check for the compatibility issues of the printer driver, which you have installed recently.
      ·It's always advised for users to better update your printer driver on regular basis to further improve the performance of your printer.
      Call us at Canon Printer Support Number 1-800-213-8289 and resolve all types of issues
Canon Printer Support Phone Number 1 8002138289 Tech Support
Posted on Sep 19, 2017
  • 586 Answers
   The mechanial is misalligned due to forcely pulled out paper.It need mechanical adjustment,If you can handle it then realligne the mechanical.
Thanks
Posted on Dec 06, 2008
  • HP Master
  • 6,487 Answers
Try first to unplug the power of the printer for about 5 minutes and then after that power it back on and check if the printer will now respond and also check inside the printer for any stuck or foreign object inside it...
    Genius:
  • 3,422 Answers
HI,
Please reset your printer by unplugging all the cords of it for 30min.After 30min. pug them back in and press the power button.This should fix the issue.
Let me know the result.
    Genius:
  • 3,422 Answers
HI,
Please unplug all the cords of your printer for 30min. and then plug them back in after 30min. Now turn on the power button.This will reset the printer and fix the issue.
How do I fix my printer?
throw it in bin
check you pc memory also
May 05, 2016 | Office Equipment & Supplies
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
My Lexmark x4850 has stopped prin?t the computer. What is wrongting . Sometimes it will print when I restar
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lY7NTO. Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark Wireless X4850 All-In-One Inkjet...
Printer not responding to print message order
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
Sep 12, 2011 | Lexmark X2600 InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
A minor problem, but annoying at the very least. The print server works very well except for the last page of print. The printer does not fully eject the last sheet of printed paper. If it's page 3 of...
change paper size setting as the printer may be set to a shorter page and that is why it is not ejecting
if nothing works then always print an extra page
it will run through the printer untouched
Apr 06, 2017 | IOGear GPSU21 Print Server
After clearing paper jam in the printer , printer is not responding for any movement . Cartridge is not moving after opening the top cover and not printing any document.
1.PLESE CHECK PRINTER BACK COVER HERE IS ONE SENSOR AND A LOCK INDICATOR . YOU FULLY SET INDICATOR IN LOCK POSSITION.
2. CHECK PRINTER CARRIGE ROD AND MAKE SURE THAT IT IS OILY.
3. CHECK PRINTER CARTRIDGE.
4. CHECK PRINTER POWER CABLE.
May 31, 2010 | HP DeskJet 1280 InkJet Printer
Printer spits out blank page before printing
Check Your Ink Catridge. If the Catridge ink is full then try the following Steps.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Mar 02, 2009 | Brother Multi-Function Center MFC-240C...
Ben Johnson
