Question about RCA P46924 46" Rear Projection Television
T.V. dead RCA projection t.v. working just fine. I moved it across room, plugged it in and now all I get is three beeps then nothing happens. Power cord seems o.k. What else could be wrong and is it something we can fix ourselves?
  • Anonymous Nov 20, 2007
    my ten year old RCA rear projection Tv will no power up...dead, is it worth fixing? last ime it did this it cost me $500.oo
    D.Dupree
    Genius:
  • 1,694 Answers
Three beeps = bad transformer.....Do you need the part # ?
If so,please provide service # from back of set......T.
Posted on Nov 30, 2007
    Scholar:
  • 150 Answers
Sounds like something has shorted out, the "three beeps" are they loud or softer, high pitched or low, would suspect that you might want to call someone out on this as it could be a number of things.
Posted on Jul 27, 2007
I have the netgear WGR614v.7 All power is out. No lights or anything. Tried the reset, no luck. Dead???
Have you tried another power cable ? If you have the same problem then yes it is probably dead.
Jan 27, 2011 | NetGear WGR614 Wireless Router
I have a rca rear projection tv model number d52w17 and when i turn it on it beeps three times and after it beeps three times nothing else happenes. i have un plugged it and waited for 30 min like a friend...
You have a capacitor that has gone bad on the HV power supply board on the left side, the number is cp150.It sits behind an aluminum heat sink in the middle towards the front, it will probably be bulged at the top. Along with that since the board will be tilted up I would re- older all the connections on the HV transformer, that's the critter with the red lead coming out of it. Your done!
Dec 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv worked fine. I moved it to a different room. When I plugged it back in the green power button just blinks and I can't make it do anything. I tryed the reset with a paper clip and nothing works. ...
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 29, 2010 | Mitsubishi WS-55511 55" Rear Projection...
MY RCA D52W20 52" WONT TURN ON!!!!!
Check the fuse on the AC filter board. If you trace the power cord into where it plugs in on the small skinny board located on the right side when looking in the rear there is a fuse on that board. If its completely dead I would suspect that fuse.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA projection, no power, no sound. recently moved.
Ur DM power board have burn capacitors,check for puff up capacitors,and replace it.Tries these websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P46924 46 in rear projection tv will not turn on
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Jun 02, 2008 | RCA P46924 46" Rear Projection Television
Tv won't come on
Beeping in that model usually refers to the flyback needing to be replaced or the Horizontal output transistor. Flyback is most likely the cause as the HOTransistor will usually blow a fuse causeing the set to be dead.
May 22, 2008 | RCA P60920BL 60" Rear Projection...
Dvd player wont work
Same exact problem as above three. Now what?
Wish I could hear how others resolved the issue - or did they? It's just over a year old.
Apr 05, 2008 | RCA DRC8320 DVD Recorder/VCR
Lost the picture
RESOLDER CIRCUIT BOARD LOOK FOR CRACK SOLDERING AT TRANSISTORS FOR CONVERGENCES
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
RCA P46924 46" Rear Projection Television Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
