*Where* is the manual standby button likely to be? *Where* is the manual standby button likely to be?
AnonymousMar 20, 2014
why does the power suddenly go off, even the light on the front goes out, then I pull the power cord from the back, and wait for a while, and then plug it back in, and the power comes back on, and the TV will workwhy does the power suddenly go off, even the light on the front goes out, then I pull the power cord from the back, and wait for a while, and then plug it back in, and the power comes back on, and the TV will work
You can't post conmments that contain an email address.
Some TV's have a manual standby button separate from the power on/off button. Check that. Have you checked the plug to make sure it works? If so, and there is no standby button, you may have a power module gone bad that has to be replaced. Hopefully it's still under warranty.
1. Unplug the fridge and move it away from the wall. 2. Inspect the power cord for damage. Replace the power cord if it is damaged. 3. Plug the fridge back into the wall outlet. 4. Set the temperature control to the desired level. 5. Push the "Reset" button, located near the temperature control panel, to reset the temp control settings. The Reset button is usually red in color. 6. Move the fridge back to its original position.
Unplug the power cord, wait a few minutes then plug it back in and check for a loose connection where the cord attaches to the TV. If it won't turn on after that, it's time to use the warranty.
You can try the following:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 9). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 9. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is fully inserted into the console.
c. Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
d. Check the on/off switch located on the treadmill near
the power cord. The switch must be in the on posi-
tion
I assume you refer to the AC power cord. Was the TV turned ON when you pulled the plug? You may have to find the RESET button and push it. The location of the RESET button is in your owner's manual.
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
With
the product turned on, open the print cartridge access door. The print
carriage might try to move into the access area. If so, allow it to
move to that position.
Without
turning off the product, unplug the power cord from the back of the
product. Unplug the power cord from the power source. The power cord
must be unplugged to allow the parts to be moved by hand and to reset
the paper feed mechanism, without the risk of an electrical shock.
Looking
in through either the print cartridge access door or the output paper
tray, you can unsnap carriage by pry back tabs or remove screws, depending on the model.
Make
sure the print carriage is loose and can move freely. You can then remove the carriage. You may have to reach through the output paper tray to access the print carriage.
Close
the print cartridge access door and plug the power cord back to the
back of the product. Plug the power cord into the power source.
1. Turn machine OFF and unplug electrical cord from wall or power strip.
2. Turn ON printer without the power cord plugged in (this will discharge the power capaciter in the printer).
3. Plug electrical power back in and turn on printer...
4. It should have reset.
Another possibility:
The scanner arm has the physical "lock" switch in the locked possition. Turn OFF printer and move the switch to the unlock position. Turn on printer.
This switch is for whenever the printer is moved to a different location and will protect the scanning bar.
