Question about Danby DPAC8399 Air Conditioner
I've got a Danby DPAC 8399-4 portable heater/air conditioner. We usually use it as an A/C but we're trying to use the heater for the winter; we just brought it out of the closet. The fan barely works (and makes a wierd noise), and when I set it to the heat setting, it makes a click and shuts off entirely. Any suggestions?
  • 334 Answers
Check for obstructuions in the fan housing that may be hitting the fan blade, causing the noise and improper air flow.
Improper air flow will cause the uniot to overheat quickly and it will shut down on its high temperature limit switch.
You may also have a bad fan. Bad bearings will make a bad noise as well. Thios will cause the same symptoms described above.
Check for abstructions, if you can find one, remove it, if not replace the fan. You can usually reset the limit by simply turning off power and turning it back on after 10 min.
Posted on Dec 07, 2008
I need to purchase the remote control for Danby premiere dpac13009 Where I can find it ?
Ebay, only 1 available. $55 free shipping.
NEW Danby Premiere Room Air Conditioner Remote Control Transmitter A2529...
Appliance Parts Pros. $48 + shipping. I would call first because they don't have it in stock. Claim of 5-6 days may not be correct.
http://www.appliancepartspros.com/danby-dpac-remote-control-a2529-950-ap4556076.html
Repair Clinic $49 + shipping. Again call first because they don't have it in stock.
Remote Control A2529 950
Jul 27, 2016 | Danby Premiere 13,000 BTU Portable Air...
Have a portable air conditioner Danby model DPAC 8399-3. Could you tell me how can I open the remote control to replace the bateries, since i lost the literature. My name : NANDO
Slide the rear cover of the remote in the directions of the way the arrows are pointing.Continue pulling gently until the cover separates completely from the unit. Insert 2 - AAA Batteries in the direction indicated inside the holder. Reinstall the cover and you're ready to go.
I hope this helped you, Nando. Thanks for choosing FixYa.
Jul 25, 2011 | Danby Heating & Cooling
Need a copy of the manual
Here's a link to the Owner's Manual for your Model Danby Portable Air Conditioner.
Your model has been discontinued, so download and print this manual for future reference. Making sure to keep it in a save, accessible place.
http://www.danby.ca/cms/uploads/products/en_manual/DPAC%20%209030%20and%2012030%20manual.pdf
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Danby DPAC12031 Silhouette 12,000 BTU...
What number fahranheit should i put my danby dpac 10061 temperature to get the room very cold
Celsius to Fahrenheit
(Celsius x 1.8) + 32 = Fahrenheit
Fahrenheit to Celsius
(Fahrenheit - 32) / 1.8 = Celsius
Hope this helps
Jun 02, 2010 | Danby Portable Air Conditioner
I have a Danby Mod.# DPAC 10061 portable A\C, the
This sounds like it could be a power supply problem. It may be very simple. I think I would first just unplug the unit, open it up, look for the PS connectors, and check/wiggle them to make sure there is good contact.
I went to the Danby's website:
https://www.danby.com/
And I was unable to find any service or owner's manuals in PDF format. The site does however have a locator for service shops. Good Luck!
da Marty
Dec 31, 2009 | Danby DPAC10061 Air Conditioner
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Danby DPAC8399 Air Conditioner Logo
433 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
