I'v having a problem with my RCA TV, it will not turn on. The green light will flash as if its about to come on, but to no avail. How can I fix this problem?
  • 505 Answers
Depending on type and model you could have a variety of problems. If it is a DLP and flashes the LED 5 times it is like a bad lamp which you can order and replace yourself. If it is an older tv and you hear it chirp with each flash as it tries to come on, it is likely a bad HV splitter. Troubleshooting from there requires working around High Voltage, which can be very dangerous.
Posted on Dec 06, 2008
4 Suggested Answers
  • 1030 Answers
SOURCE: RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
Posted on May 12, 2008
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
rylee_smith
  • 8619 Answers
SOURCE: I have a RCA D52W17 rear projection T.V. When I
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 21, 2010
My RCA 42" HD flat
sounds like it needs new caps on the power supply board..............easy fix if you can use a soldering iron........
cheers
Apr 07, 2011 | RCA L42WD22 42 in. LCD Television
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
RCA = flyback?
I just posted a reply to you. Its most likely not the flyback causing that symptom.
Oct 05, 2008 | RCA D52W19 52" Rear Projection Television
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Tv not turn on
the problem is the capacitor located at the powersupply...try to change it...
Aug 01, 2008 | RCA HD52W58 52" TV
Green light flashes
Same thing here....RCA tells me to count the times the light flashes as it apparently is set to "tell" you what the problem is.......3 to 5 flashes means your lamp is messed up.....they are over $300 to replace!
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't turn on.
Possible power supply problem or horizontal circuitry....
Best to have a tech check it....light box chassis comes out
fairly easy to go to a shop for analysis.......T.
Nov 06, 2007 | RCA D52W15 TV
Televison & Video Logo
Top Televison & Video Experts
