Question about HP (5064-6630) Motherboard
Cannot enter bios
I have a HP 850 mhz motherboard that I have been using for months on a backup computer. But I have forgotten how to enter the bios. I have tried several combination of keys but cannot get into to it. Can anyone tell me which key to use or what's going on?
    President:
  • 2,961 Answers
Normally with HP it's either F2 Enter or Del on boot up. But if it just stops when trying to get into the bios, the bios chip may be faulty. You can also try putting the jumper on the JBAT1 or CLRCMOS terminal on the mobo from pins 1-2 to 2-3 then back to 1-2. This will then force the pc to boot into the bios menu.
Posted on Mar 23, 2007
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Have a motherboard in my computer that stopped working. It is MCP61PM-HM 2.2. I ordered a new motherboard only to find out that the one I ordered was MCP61PM-HM 1.0B. My question is are they compatible?
Seems like the 2.2 is a new version. It supports a
  • Phenom with Quad Core technology (AM2+) up to 9600 (up to 95 watt)
  • The link below has the specs of your original MOBO...
    http://www.softunique.com/ECS-MCP61PM-HM-Nettle3-GL8E-Motherboard-HP-ver-22-MCP61PM-HM-V22.htm
    Here are the 1.0B specs:
    MCP61PM-HM REV:1.0B SOCKET AM2 MOTHERBOARD
    Motherboard description Motherboard manufacturer's name: ECS MCP61PM-HM
    HP/Compaq name: Nettle-GL8E
    CPU/Processor Socket: AM2
    Supports the following processors:
    Athlon 64 X2 with Dual Core technology up to 5600+ (up to 89 watt)
    Athlon 64 less than 4000+
    Sempron less than 4000+
    Front-side bus (FSB) 2000MT/s (2.0 GT/s)
    Chipset NVIDIA GeForce 6150SE nForce 430
    BIOS features System BIOS core brand: Award
    Keyboard combination to used to enter BIOS: F10
    Form factor Micro-ATX: 9.6 in X 9.6 in
    Memory Dual channel memory architecture
    Four 240-pin DDR2 DIMM sockets
    Supports PC-4200 (533 MHz), PC2-5300 (667 MHz), and PC-6400 (800 MHz) DDR2 DIMMs
    Non-ECC memory only, unbuffered
    supports 2GB DDR2 DIMMs
    Supports up to 8 GB on 64 bit PCs
    Supports up to 4 GB* on 32 bit PCs
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Jul 07, 2011 | Computers & Internet
    Can i upgrade my amd duron 850 mhz to 1.4ghz?
    yes, depending what motherboard you have. almost all of them will support 1.4 ghz
    Jan 01, 2011 | AMD Duron , 850 MHz Processor
    I FORGOTT THE BIOS PASWORD FOR MY NX9010 HP . WHAT CAN I DO?
    This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
    A. By Using the Motherboard Jumper:
    In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
    Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
    When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
    Make sure to turn the PC off before opening the cabinet and resetting the jumper.
    B. By Using Software:
    I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
    BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
    BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
    May 25, 2010 | HP NX9010 Notebook
    How do I reset my bios password? I can' not enter bios it asks for an admimistator password.
    May 20, 2010 | HP Compaq 6530b Notebook
    Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
    The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
    Here are the details:
    Motherboard manufacturer's name: ASUS A8M2N-LA
    HP/Compaq name: Nodus-GL8E
    CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
    Front-side bus (FSB)  2000 MegaTransfers/second
    Chipset  GeForce 6150 LE chipset
    BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
    Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
    PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
    Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
    Armada E500 BIOS reports wrong processor speed
    Check Compaq's support site for any driver or utilities download for the chip set.
    Aug 09, 2008 | Compaq Armada E500 Notebook
    Motherboard processor support
    Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
    754558-200 or later
    A01450-200 or later.
    See the board revision note, below, for an explanation.
    800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
    Sergio
    Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
    PROCESSOR
    Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
    Athlon (Socket A) (600 MHz - 1400 MHz)
    Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
    Athlon MP (1000 MHz - 2133 MHz)
    Duron (550 MHz - 1800 MHz)
    Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
    Mobile Athlon 4 (850 MHz - 1400 MHz)
    Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
    Mobile Duron (650 MHz - 1200 MHz)
    I Recommend to go for Athlon XP with good cooling fan. :)
    Dec 18, 2007 | EliteGroup K7AMA Motherboard
    Open Questions:
    See all HP (5064-6630) Motherboard Questions
    Computers & Internet Logo
    183 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
