Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I need a PWB POWER SUPPLY for a WD-62525 MITSUBISHI DLPTV
The picture went out on my 62" MITSUBISHI DLP TV while we were watching it.The lamp L.E.D. on the front of the TV came on solid red.I had just replaced the lamp about 2 months previously....but the lamp is GOOD. I replaced the lamp ballast,and the same problem exists.I can only assume the power supply feeding the lamp ballast is bad.I want to replace it.Where can I order a PWB POWER SUPPLY from?
  • dj5james Dec 18, 2008
    I got the red LED so I replaced the lamp for the first time, yet TV still did not work. Repair center said lamp ballast is defective and will replace it for over $500. Did you replace your own or pay someone else. I'd hate to pay someone a couple of hundred dollars to do something I could.
    Sergeant:
  • 302 Answers
1-800-553-7278, this is mitsubishi parts dept
Posted on Dec 06, 2008
My tv went off an red light is blinkin
The red light indicates that the lamp has failed to light. You need a new lamp or the capacitors on PWB-Power need to be replaced. Try getting a new lamp first.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
We have a Mitsubishi 65 inch dlp hd 1080p and we had a bad storm but we do have a surge protector on the tv. When we went to watch the tv after the storm it turned on fine but the dish had to reboot. After...
Something died in there - perhaps a capacitor or a solid state device just blowing and cracking into pieces. happens. Open up the set and see if you can spot it around the power supply area.
Aug 30, 2017 | Mitsubishi WD-62525 62" Rear Projection...
Do i need to change my lamp? or is something else?
is your tv a dlp?
maybe it can be you tv lamp..
need to know first.
Jan 25, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv totally black, with the red light of lamp on.
sounds like the 34 error which is caused by the power board capacitors. you can get the repair kit that should repair that issue. The kit contains the replacement capacitors and step by step instructions. Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replacement lamp fine for 10 days. Now I get sound but no picture
The ballast hardly ever goes out on your model. Its more likely failed capacitors on the power board which is the cause of the solid red lamp led. Heres alink to the repair kit for your model and it contains the replacement capacitors and step by step instructions with pictures.
Jun 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red light stays on after lamp replacement and reset
if the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
373 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
