Question about Husqvarna Chain Saw 20" Bar
Bogging down i have a huqvarna the saw ran great till this year now when i run it under a load it boggs down and tries to cut out. i have cleaned the fuel filter, changed the spark plug, cleaned the carborator pretty much i have done everything i can think of and still have the same problem.
  • 211 Answers
Hi
The 2 stroke engines,your chain saw as well need to be check every year due to the carbon deposit from burning gases.Check if the engine is sealed properly(gaskets from carb,cilinder,crankcase and the seals.Pay attention at the flyweel key(not to be sheared off)crankshaft,piston,piston rings,piston rod.
regards savumihai71
Posted on Dec 06, 2008
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
1992 60 hp motor bogs under full power????
try priming the fuel bulb when it boggs down and if it speeds up then replace fuel pump diaphrams etc and clean carbs and balance to start a fresh ! fuel tank clean ?
Jul 24, 2014 | Seloc Johnson Evinrude Outboards 65-300HP...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Yesterday i was using the 455 rancher its a huqvarna. it was working fine then, i went to use it again a little while later and when i went to cut with it it started bogging down and had little power.so i...
When it won't run correctly, try removing the fuel tank cap temporarily. If it immediately picks up, suspect tank venting problems. Good luck!
Nov 12, 2010 | Garden
I have a husqvarna 450, has ran great for a year. After running out of fuel, it would restart, but bogs out at higher RPM until it dies. Checked air filter, drained/replaced with new fuel (good mix),...
Check the fuel filter for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight, especially the carburetor to cylinder fasteners. Did you check the lower chamber diaphragm when you were working on the carburetor? It should be flexible with no holes or cracks. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to other brands of carburetor as well. Hope some of this helps!
Aug 08, 2010 | Husqvarna 450 e-series 18" Chain Saw
Saw runs great then bogs down 20 sec. after i start cutting i let off it runs good then bogs again when cutting after a few sec
Check your air filter, if clean chances are your carburetor needs to be rebuilt. the carburetor has thin diapragms that get hard and won't meter the fuel in fast enough.
Jan 30, 2010 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Carbeurator adjustment. Bogs down under load
Try making small adjustments to the "H" needle. CCW is richer and to rich is better than to lean.
You may also find this helpful
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
A plugged up muffler can also cause slow response and cut power. To rich a fuel/oil mix is usually at the heart of a plugged muffler. HTH
Lou
I use 50:1 in all my saws.
Jan 06, 2010 | Poulan Pro Chain Saw 46cc 20"
Loses power when trying to cut wood
Check the muffler screens first. Then the spark plug. If not the case, then adjust the High setting on your carb. Prolly starving for fuel under engine load. If it is still a problem, Pull the carb and clean it.
Apr 27, 2009 | Homelite ZR10926 16" Chain Saw
Runs but boggs out when given gas
If you don't already, pump the primer/purge till it's full of fuel before starting
Apr 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Husqvarna Chain Saw 20" Bar Logo
245 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
