Question about Zenith XBV243 DVD Player/VCR
Zenith XBV243 CD player keeps ejecting disk
When I put a CD into the player it is ejected repeatedly. If I keep putting it back in, it will finally play.
    Problem Solver:
  • 7 Answers
You may need to try a cleaning disc to remove dust from the laser heads, as dust may be impeding the player from recognizing the disc type.  Also, double check the manual to see what disc formats your player can handle.  All players have a variety of formats they accept or reject.  If the owner's manual verifies that it does accept that CD format, try the cleaning.  If that doesn't work, it may an issue that will require an authorized service center to look at, which may not be work the cost as replacement DVD players are very inexpensive.  Avoid combo players such as the DVD/VCR combo, as when one quits performing, you either have to replace the entire unit or add a new single component for the bad one.  Hope this helps!
Posted on Dec 06, 2008
My cd doors wont open what can do.
Hi.
Try disconnecting power. Connect back and then turn the DVD on by using the button in the player (not the remote) while at the same time you keep pressing repeatedly the eject button on the player. You will need to keep pressing eject until the unit start loading the disk.
If that does not work, then the DVD must be disassembled undoing the screws holding the top cover in the chassis.Once disassembled there is usually a disk stuck inside the drive or a mechanical issue. The disk tray motor rarely fails.
Do not disassemble the player unless you have repair experience. Before proceeding check warranty status.Call Kenwood if you want to book a repair
Regards.
Ginko.
Feb 03, 2011 | Kenwood CD-223M 200-Disc CD Changer
XBV243 DVD Player / VCR Combo: my Zen XBV243 DVD/VCR combo player won't eject the...
If it is the same problem as mine, the drive belt is old and worn and is slipping- therefor the tray will not open. I found this out after I removed the metal cover, and the screws holding the DVD assembly to reveal the motor, pulleys, and drive belt. Now the real problem is to find a replacement belt. Possibly a o-ring the proper size may work, as they are quite easy to find. The original belt has a square cross section, whereas an o-ring has a round cross section, but should work well enough.
May 05, 2010 | Zenith XBV243 DVD Player/VCR
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
Can't get a dvd to eject from from a Lexus cd player
basically just carefully insert another CD into the slot, but only about 1 to 2 inches of the disk and keep jiggling the disk around and pressing the eject button.
This was a suggestion for the lexus owners club wed site.
give it a try and if it doesnt work let me know and I will try to find something that does.
Jan 10, 2009 | Bose & Wave& Music System
VCR accepts tape, then turns off
I think that there is something wrong with the tape you are using. The locking mechanizm is stuck and when the VCR can't turn the reels it will eject the tape. I'm assuming that you didn't try other tapes to see if it acts the same. You can unstick the locking mechanizm by putting a pencil or something like it in the 1/4" hole between the reels on the back side of the tape. Just try pushing down on that brake release. This has worked for me. Good luck.
Jul 04, 2008 | Zenith XBV243 DVD Player/VCR
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Doesn't eject my disks
    I held my eject button down for more than 3 sec and it spit the DVD out and cleared the eject code when I reinserted it. Try it and see. But make sure it's a CD/DVD you really don't care about.
    Feb 02, 2008 | Kenwood DDX-6019 Car DVD Player
    Cd is stuck
    put the same disk in , play it for a while then eject it properly.
    Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
    Zenith XBV243 DVD Player/VCR Logo
    270 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
