Question about Sharp R-319FW Microwave Oven
Display lights the display lights on my microwave have become very dim and nearly impossible to see. it works fine otherwise.
  • Jen Spencer Jan 07, 2009
    Just last week, I thought my microwave had died. I went to take a look at the standard "colon" (since the time's never set) and it wasn't lit up. I freaked out a little, and then investigated. The microwave functioned properly and I could see (just barely) the display if I turned off all the lights in my kitchen.
    One thing that I did notice, which scares me, is that on the holes where the door hinges click into place (on the inside of the microwave, to the left of the display), there is some black soot looking stuff. I've never burned anything in my microwaver, so I don't know if the display bulbs just got too warm or if they are displaced like the second solution said.
    I really am happy with the way the microwave performs, I just wish that the display would be brighter. I tried calling the 1-800 number, but it's after-hours and no one was there to help. I guess I'll try again tomorrow.
  • 944 Answers
If the lights are attached to a circuit board behind the front panel, it is possible that this has come adrift and is sitting back from it's design position - this is relatively easy to solve and is a relatively common problem especially if the oven has been often moved around or if buttons have been pressed a little too hard. Possibly a supply voltage fault could cause this, especially if the lights in question are incandescent bulbs rather than LED's, however if the whole oven appears to function fine apart from dim lights, then this is unlikely to be the problem. HOWEVER, unless you have a reasonable knowledge of this sort of equipment, I would not recommend carrying out a repair yourself as microwave ovens are notorious for injuring amateur repair personnel due to high voltages stored in various electronic components even after unplugging the machine. Recommendation is to get it to a service agent - If you are confident that you can safely open the cover, then please do so just to see if the small circuit board where the lights should be has shifted - only touch things inside the cover if you are absolutely sure you know what you are doing. If this appears to be the problem then either get it repaired professionally (should be a five minute job at most), or ask me for more details if you feel you want to try yourself.
Posted on Feb 17, 2007
  • Sharp Master
  • 9,149 Answers
This is a problem in your control unit assembly. We regularly repair these assemblies for only $32.50 nationwide. If you or a friend want to do the disassembly to send it in, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 19, 2007
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Whirlpool microwave g2 - Panel lights but no text visible
It is a logic problem or at least electrolytic capacitors that dim the display too far. The display could be repaired if it isn't a ic (logic) problem if it is then you need the whole display replaced
Nov 29, 2013 | Microwave Ovens
Display very dim
Thats just judgemental, depeding on sentimnets you have for it...ask yourself a question: why would you buy a new MW if the one you have does the same as the new one you would probably buy?
Nov 28, 2013 | Frigidaire FMV145K Microwave Oven
GE JNM 1851 microwave display panel light is out
The GE Answer Center is telling it like it is. Bet it's touted as a customer-friendly "improvement".
Sep 05, 2017 | GE Microwave Ovens
Selection. Panel not working goes F3 locks unable make selection 4abot 30min
Judging by the description you have provided, the problem is in the keypad control board, it has become intermittent making the use of the microwave oven nearly impossible, and considering the price of the part replacement, it will exceed the cost of some new microwave ovens.
Apr 11, 2012 | GE Microwave Ovens
It's a GE microwave..model PVM1870SM1SS...mfg. 10/07..panel light is VERY dim...cannot read unless you shade all light with hand otherwise works fine...tried re-boot twice no affect.All other GE...
It sounds like you need a new display, if it is neon or a new back light if it is an LCD.
Contact the manufactureres web site for details of a dealer in your area for spare parts.
Hope this helps.
Nov 16, 2010 | GE Advantium 120 Convection/Microwave Oven
R-1751 display issue and the work light is on always
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 17, 2008 | Sharp R-1750 Microwave Oven
Microwave display - digits have become dim / partialy missing
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
Full details and *critical* safety, disassembly, and troubleshooting info is at Web our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 09, 2007 | Microwave Ovens
Sharp R-319FW Microwave Oven Logo
276 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
