Home | HP | Compaq FP5315 (Black, Silver) 15" LCD Mon... | When i switch on my P.C...
HP Compaq FP5315  15" LCD Monitor
Problem for HP Compaq FP5315 (Black, Silver) 15" LCD Monitor
When i switch on my P.C. and my FP 5313 screen it flickers
By lescandler on Dec 06, 2008
as i switch on my screen it flickers, so i have to switch it off for a while only to try later for it to be ok. Or i switch the pc onand the screen later which also works but not ideal..........any ideas?????
Same Problem
Apr 30, 2009
-   Same problem here, would really like a solution -   Guest
Apr 29, 2009
-   I have the same sort of problem, sometimes when I switch it on or if it goes into hibernation it won't always come back on. I then have to mess about with the wire at the back or the mouse and it eventually comes back on (not sure what the trigger is that brings it back though)-   Guest
Apr 22, 2009
-   same problem for me as well. So I always switch ON my monitor 5 mins after switching ON my PC.-   Guest
Jan 21, 2009
-   same problem :/ when you turn on the computer it flickers so i have to pull the plug from the screen for a few minutes and repeat untill it works :S-   rusty321_46
Best Solution
posted on May 09, 2009
Very Helpful)
John Snyder
Rank: Apprentice
Rating: 100%, 1 votes
This is a known problem with a series of components inside the monitor. There are about 11 capacitors that if replaced will allow the monitor to function properly.
The best place to go to read more is http://www.badcaps.net/forum/printthread.php?t=2658
The list of the capacitors that are bad are below with possible replacements.
C922, C925: Hermei LE 1000uF 16V, low impedance, general purpose, replacing with 1000uF 16V Samxon GF.
C201: Hermei LZ 150uF 25V, ultra low impedance, high ripple current, replacing with 1000uF 25V Samxon GF.
C924, C926, C929, C930, C932, C933: Hermei LT 470uF 16V, high ripple current, low impedance, replacing with 1000uF 16V Samxon GF.
C207: Unknown CD110 50uF 4.7uF (general purpose), replacing with a 35V 4.7uF tantalum unit (SCP/Short Circuit Protection pin on TL1451 won't get anywhere near 35V).
C907: WC (with stylized Westinghouse W) SM 22uF 50V (general purpose), replacing with 63V 100uF Samxon GF (used for SMPS controller Vcc filtering).
C905: Hermei HT 100uF 400V, standard, general purpose, leaving as is - generally no problem.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 06, 2008
Somewhat Helpful)
Big Poppa Ma
Rank: Wiz
Rating: 82%, 123 votes
sounds like your monitor is going bad
Was this helpful?
Yes
No
Popular Solutions for HP Compaq FP5315 15" LCD
Questions and Unsolved Problems for HP Compaq FP5315 15" LCD
Do you recommend HP Compaq FP5315 (Black, Silver) 15" LCD Monitor?
Answer
Answer
Hi, i have the same problem. My brightness randomly changes, and a message comes up "Waiting... (More)
Answer
no volume on speakers, or not working at all.
Answer
it comes on and off will not come on all the way,i've chicked the power cord not that
Answer
I've just formated my computer and when i switch it on my Monitor comes clear then fades in... (More)
Answer
my compq nc4010 screen broke so im using the vga port on my tv the screen apeers during the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Compaq FP5315 15" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 1436
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
