Question about Sony HVR-A1E HDV Digital Camcorder
How can I avoid camera moisture condensation on my Sony a1e camera, it keeps saying turn off for one hour or eject tape and is doing this constantly.
  • Anonymous Dec 12, 2008
    Have tried drying it... no luck.
  • 10,594 Answers
Camera gives Moisture error sign if it really have moisture condensation inside or its moisture sensor itself got defective.
if moisture is inside, blow hot air in camera mechanism for 5-6 minutes by hair dryer (not so closed with mechanism) and check / test.
If problem still exist it means moisture sensor is defective and i know its Sony high-end model camera and know how to fix it yet I would recommend to take camera to Sony Service center for proper repair.
Posted on Dec 06, 2008
My sony hdr-hc1 cmacorder is saying moisture condensation turn off for one hour but its been more than an hour
Leave it in a warmish dry place for as long as it takes. Condensation on the tape mechanism will cause the tape to cling and get snarled and tangled in the drive. You also need to make sure that the tapes are completely dry. Exposure to cold then warm air will cause condensation even without any rain or other obvious wetting. If the problem does not clear up overnight, then there may be a fault with the sensor, but give it plenty of time.
Nov 29, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
Sony DVC-TVR20 won't accept tapes
most of the errors get solved with a hard reset
did you try it?
leave the unit plugged off from power for few hours
Jul 17, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
What does C:31:22 mean?
Per the manual
C means you can fix E means professional service needed.
21 is moisture condensation. icon of rain drop in a box will flash on screen unless moisture in lens Eject tape let sit 1 hour or more to acclimate
31...manual says to eject cassete and reinsert, operate OR daisconnectpower cord andremove battery, reconnect, operate.
Mar 08, 2009 | Sony Handycam CCDTRV118 Camcorder
CONDENSATION
Condensation message comes when video head drum got moisture and such moisture can damage tape and video heads. So camera stops function of tape loading and play/ rew/ ff.
Eject and take out tape, if any in camera and blow hot air by hair dryer for 1-2 minutes from at least 6"distance in tape mechanism.
This will evaporate any moisture on video head drum.
and if camera still gives error then dew sensor in camera is bad and you need tech person to replace it.
Dec 16, 2008 | JVC GR-D33US Camcorder
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Tape/Display problem
Straight from the manual:
C:21:ss Moisture condensation has occurred.
-> Remove the cassette and leave your camcorder for at least one hour to acclimatize (p. 291).
Mar 12, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Sony Handycam CCD-TRV37 Code C:31:10
it is whats called moisture condensation. this happens when the camera goes from a cold to a hot environment very quickly, and vice versa. Simply leave the camera standing with the tape door open for about an hour, and then try again. If this does not fix it, then try cleaning the video heads, and make sure the camera is not in a humid environment, as this will also cause this to happen.
Dec 28, 2007 | Sony Handycam CCD-TRV37 Camcorder
Code 32:11 will not eject tape sony tvr67
The mechanism got stuck. Open the cassette compartment screws and apply external DC to the Power input and eject the tape. If this is not possible refer to a skilled technician. If you need the service manuals and mechanism for replacement write to us.
Dec 07, 2006 | Sony Handycam CCD-TRV67 Camcorder
Constant Eject Tape iluminated on screen.
Are there any error codes listed? Usually when a camcorder constantly ejects the tape it is because of a fault being present, the most likely one is moisture. Leave unit in a dry environment for a day with the cassette door open then try it. If you are sure the unit does not have moisture in it you probably have a bad moisture sensor. They go bad frequently. It is the small square device usually located on the deck base near the video drum and sometimes on the base of the drum. I do not know if you are capable of replacing this unit. If not you will need to find a reputable repair facility to get an estimate. Keep in mind from the description you gave of the problem it could be about anything. This is just the most common problem for this symptom. Several websites which offer free estimates are: http://www.videotech.com or http://www.camcorderrepair.com or http://www.videoonerepair.com Good luck.
Jun 15, 2006 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sony HVR-A1E HDV Digital Camcorder Logo
435 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
