Question about Electrolux Vacuums
I have a modle # 1584 electrolux central vac no suction. This modle has a lid not a canister. Motor goes on. Need help
  • PCFC Dec 07, 2008
    I did still nothing
  • 125 Answers
Likely is a leak somewhere. check all the outlet doors
Posted on Dec 06, 2008
  • Denny Adams
    Denny Adams Dec 07, 2008
    definately a leak somewhere check all your pipes while its turned on
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
My electrolux central vac outlets work on the main
You might have a plug or clog in the upstairs lines. for information on how to remove a clog in a central vacuum system see this article:
http://centralvacproducts.blogspot.com/2009/01/how-to-unclog-central-vacuum-system.html
Oct 24, 2009 | Electrolux Central Vacuum
Low suction
1) Have you checked the filter? If it is clogged your suction will be low. Also, you could have a pipe loose where you can't see. Make sure that you can get a coin to go all the way through the hose. make sure the suction motor ( the unit ) is coming on.
2) Call the repair man.
Aug 10, 2009 | Electrolux Central Vacuum
No suction but good exhaust flow
This sounds like you have a loose pipe connection somewhere in your system. Physically check all connections. If you can't find anything suspicious, call a vac repair man that specialies in central vac repair. Joe
Aug 10, 2009 | Electrolux Centralux Vacuum
EL7020A ELECTROLUX VAC SHUTS OFF AFTER 10 MIN
The symptoms you describe are typical of a vac that has a blockage (hence poor suction). It cuts out because it's over-heating. You need to check the hose, the filters and anywhere else where something may have got stuck. Blockages are often caused by things like paper clips, but can be caused by something as apparently harmless as a piece of paper which gets stuck and then debris builds up behind it and causes a log-jam.
Feb 10, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
No suction
On some units there is a screen that protects the impeller of the motor. If this gets sealed off with debris then it is like putting a potato in the tail pipe of a car. Taking the top off the unit reveals the motor. DO UN-PLUG the unit first from the electrical outlet. Take off the exhaust piping if any to allow the motor to be lifted out of the canister. There is typically enough wire to allow this without taking any wires off. Look at the bottom of the motor to make sure the nut has not spun off the impeller and it is still attached to make suction. The look at the hole (aprox. 2" round) to make sure it is clear of any debris. If it is not clean it and re-install everything. If the impeller is off the motor it is new motor time.
Hope this helps!!
VR
Sep 09, 2008 | Electrolux Central Vacuum
I have Electrolux canister vac. The suction end pops open everytime it loads up.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Generic problem for all Vacuums
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Electrolux central vac, floor sweep malfunctioning
For 9.99 I'll tell you how I did it. Thankyou very much.
Mar 08, 2008 | Electrolux Centralux Vacuum
Electrolux central vac problems
I work on many types of units. If you electric floor brush runs but you have no suction then there is possibly a problem with the relay board that allows you to turn on the suction from the hose handle. This is a low voltage (24 V) switching loop circuit that will cause the 120 V motor in the unit to run.
Inside the wall valve are two brass pins. NOTE: there are 120V valves installed on some systems known as a Super Valve. A shock hazared exists if you work on that type of valve. That being said. In the round portion of the valve you can use a garage hose that has a 360 deg. chrome ring to test the valve. The ring completes the circuit causing the unit to power up and suction at the end of the hose. If the suction is weak, there is a colg in the pipe. If you hear no airflow, the relay inside the unit did not energize or the motor is bad.
To test: go to the unit and turn the switch on the side to "manual" if the unit turns on the motor should be ok. DO NOT RUN THE UNIT without and open valve. In some brands dammage to your motor will occure.
If the unit did not run, look for a small button near the switch. This is a circuit breaker for the motor. If it is poped out and you hear a "click" when you press it in there is most likely motor problems and someone should be contacted for repair.
Hope this helps!!
VR
Mar 07, 2008 | Electrolux Central Vacuum
Vacuums Logo
138 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
