Question about Sharp R-1480 Microwave Oven
Sparking microwave sparks when i try to use it now whats the problem? i think its something simply but i don,t no what to change
  • Sharp Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Posted on Dec 07, 2008
Sparks form the right side inside the microwave
take it in for a proper diagnosis
there are to be no sparks from a microwave inside or outside
Dec 05, 2016 | Microwave Ovens
Sharp carousel R-930-AK microwave is sparking how to stop it afraid to use it
Sparking could be caused by something metallic inside the microwave! Check in side for anything metal like foil!
Nov 02, 2014 | Microwave Ovens
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Microwave shooting spark on inside of oven when turned on with nothing in it
It is bad for the oven to run it empty, is there something where sparks were and try it with a cup of water.
Dec 26, 2009 | Daewoo KOR-860A Microwave Oven
Microwave sparking inside when I try to cook something ! anything ! what should I do ?
microwave ovens tend to spark if anything inside it is metal. that includes the metal design that is often painted on the edging of plates. make sure you have nothing metallic in the microwave.
please take a moment to rate this solution thanks
robert
Oct 29, 2009 | Daewoo Microwave Ovens
Microwave sparked out now it does not work
You had something metal inside the microwave. Do you have a rack inside on a revolving tray? On my microwave, if the foot of the wire rack is not on the revolving tray, it will spark against the floor of the oven. Microwave will go around round pieces of metal - it will spark if it finds a flat surface. I dont think you did any damage to your machine but try to not do this again.
I hope this helps you.
Sep 08, 2009 | Microwave Ovens
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Wolf Microwave -- Loud Pop and Sparks
Is it safe to use your microwave if it pops like this all the time randomly... And sometimes lights up in the back like a spark or something???
Nov 19, 2008 | Microwave Ovens
Problem
check halogen light holder and connections, and any damage body, check inside body of microwave oven , because of microwaves some sparks comes from damaged body..
Oct 18, 2007 | Kenmore 63793 Convection / Microwave Oven
Sharp selling bad microwaves
paddy paddy paddy i want i want, bet you were spoiled as a child, never continue to use a microwave that sparks, you can only do more damage to the appliance and maybe even worse is this sparking when you use it under normal conditions, place a plastic bowl with cold water in and see if it sparks then, if not then is it something you have done, i assume you know what you can not put in a microwave if sparking occurs anyway, and its only 6 months old, is it under guarantee, then its simple, send it back and ask for free replacement SHOUT AT THE RIGHT PEOPLE DON'T WASTE TIME ON HERE
Oct 04, 2007 | Sharp R-220BW Microwave Oven
Sharp R-1480 Microwave Oven Logo
54 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
