Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag mav7000aww washing machine doesn't work
My washer suddenley doesn't work. its like there is no power to it. I did one load of wash and worked fine. and tried to add another load but no water or power on it.
please help
  • 4 more comments
  • Anonymous Dec 07, 2008
    I still have the same problem. we checked for power and the power is there and all the wire seem to have power to it. the washing machine does not spin or fill with water. like i said before its like its dead. please help
  • egberndt Dec 24, 2008
    Same thing just happend to us too. I check for power and there is definitely power there. I think it may be the circuit board. Can anyone confirm?
  • Michael J. Orlando Dec 30, 2008
    same problem.  Maytag mav7000aww filled w/ water and then just died.  Won't run on any cycle.  I bailed out some water and even tried to refill and it won't do that either.  Seems to have lost all power.  Please advise.
  • RonnieT24 Jan 12, 2009
    In the course of troubleshooting my leak problem, I tipped the entire lid assembly back. I found the problem (I think) causing the leak was that my tub retaining screws had not been fully tightened. I had removed the tub a couple of months ago to troubleshoot/investigate a transmission issue which ended up being just the bearing. Apparently when I put it all back together I was too tired (or lazy) to fully tighten the screws. Anyway, during the effort to find that, the lid got tipped all the way back and all the detergent in the receptacle drained out the bottom. Initially I thought it would be a problem but I was able to complete two more loads with no problems and no more leakage but after I declared the thing all better and turned it over to the wife it naturally refused to work. My theory is that the detergent must have seeped into the works but I need a little guidance as to how to systematically check each of the components. Visual inspection showed no apparent water damage. The wiring diagram found inside the unit mentions a 10 amp fuse but I was unable to locate that. Any clues gang?
  • RonnieT24 Jan 16, 2009
    The part cost me more than $25 ($33 to be exact) but it absolutely didtake care of my problem. One quick note to anyone trying this. I madethe mistake of not reconnecting the tube to the water level sensor,mostly because I didn't notice that it had come off, but that led tothe first load my wife did flooding the garage. The tube is located onthe left side of the assembly and attaches to a cylinder on the tub anda small connector on the water level setting assembly. Needless to say,you REALLY want to be care with this if your machine is in the houseand not in the garage like mine. Like I said I did not disconnect thisthing on purpose, it came loose on its own as I was moving thecontroller assembly around.
  • Anonymous Mar 01, 2009
    (MayTag MAV7000AWW) I have a piece of rag lodged around the bottom of the spinner in the center of the washer, it won't budge how can I remove the rag?
Ok, I figured it out, at least my problem.  The short answer is that you need to replace the lid switch assembly, maytag mav7000aww part no. 12001908.
To verify you have the same problem as I do, remove the rear cover to the control panel (three philips head screws and two machine bolts, see http://www.partselect.com/ModelFrames.aspx?ModelID=117917&ModelNum=MAV7000AWW&mfgModelNum=&ManufactureID=1&Selected=52442&Position=2&mfg=Maytag&Type=&Mark=2 no. 14.)  Use a volt meter to verify that you have power coming into the lid switch assembly harness (black wire).  Use the volt meter to verify that you have no power coming out of the lid switch assembly harness (red and yellow wires.)
To further verify that you have the same problem as I do, remove the wire harness from the lid switch assembly and use a ohm meter to verify that the switch is not allowing power transmission.  In the lid closed position (lid switch depressed), use ohm meter to test line-to-motor and line-to-machine connections.
If you verify that you have no power down-circuit of the lid switch assembly using the two methods above, then you have my problem.  In this case, you can purchase the part noted at top for less than $25.
Posted on Dec 31, 2008
2 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: maytag mav7000aww washing machine doesn't work
check your lid switch
Posted on Dec 28, 2008
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
How to fix a errow ob on maytag washing machine
OB is an out of balance load error, try re-distributing the clothing and see if it helps, also make sure the machine is level, if this doesn't help there may be a fault with the out of balance switch or lever.
Mar 06, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis MAV-14
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Washer MAV7000AWW Washer fills as it
Sounds like a bad timer motor.
Try watching the timer motor and see if you can see it moving .
Jun 09, 2009 | Maytag Atlantis MAV7000
Maytag stops at any cycle after warm
sounds like a motor problem. the motor might have reached then end of its life and is overheating causing the thermal overload protector to shut down the motor.
Sep 09, 2007 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
950 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
