Question about Aspire X-Navigator ATX Mid-Tower Case
No power I was wondering if I have to have a motherboard installed to get the fans going? If not. I have no power. Could I have hooked it up wrong? I had a bit of inswtruction problem with where the output .5 amp went after I conected all the fans together. Thanks
  • 624 Answers
Your power supply will not supply any power unless there is a motherboard or other appropriate device connected to it; safety feature.
Posted on Feb 15, 2007
I have my rest and power hooked up in the right plugs but nothing is happening only thing comes on is the light to the motherboard when plugging the power from the computer case to the motherboard the...
Hello
You may have the reboot or restart wires backwards.Or on the wrong pins on the motherboard.
Here is a link to your mobo. Shows correct hook up.
Also be sure your memory sticks are in proper slots.If you have 2 they need to be seperated.
One in one channel the other in the second channel slot.Usually the slots are color coded.
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Aug 09, 2011 | ASUS P4P800-VM Motherboard
Have replaced this board, hooked everything back into its place, have checked off/on switch,have tried another power supply, yet, when i push the off/on button the fans jump but the green light on the...
Hello, You might have a bad motherboard and need to replace.
First, I know its a pain but disconnect and reconnect all cables verify that your not missing one of your power cables look for any connections on the board that don't have cables hooked up to it. take extra care when hooking up your power button cable. Its easy to accidentally place them in the wrong pin.
Hope This Helps
Jan 30, 2011 | ASUS PTGD1-LA Motherboard
Cooling fan won't come on when car is up to temp. Fan came on when power wire to it was grounded out. The new thermostat is hooked in but does not work either. Wondering is the coolant temp sensor is bad...
Sounds like you should take it to a qualified repair shop to have this sorted out. new thermostat is hooked in but does not work either. ??????? The thermostat does not open ???? Engine over heats ? You put it in backwards . Cooling fan relay turns on the cooling fan . It's tough to guide someone through a diagnostic procedure when then don't have any idea how the system works .
Jul 18, 2017 | 1991 Chevrolet Cavalier
No respose
Maybe your power suplly can't work well with your mobo
try to replace the power suplly
Jan 30, 2009 | AOpen AK77-8XN Motherboard
Motherboard not working correctly.
The way that I solved the problem was to unhook each and every connection to the motherboard except for the 4-pin and 24-pin power supply connections, the processor, the cpu fan and the power on switch connectors, once I have done that, then I plugged in the power supply and turned it on, in which that worked! After that, I would hook everything up to the motherboard one piece at a time, in which after each piece I would turn the power supply on again to see if that was the problem. Starting with the hard drive, the memory sticks and then the DVD drive, and found out that was the problem. The cable between the DVD drive and motherboard was the wrong cable for that motherboard. I will purchase a new cable and see if that works!
Apr 21, 2008 | EliteGroup 945G-M3 (V1.0b) (945GM310B)...
P4vmm2 motherboard wont start
cheak and change ur power supply
Jan 05, 2008 | EliteGroup P4VMM2 Motherboard
Motherboard C51G-M754
This may be a silly question, but have you plugged the 4 pin power cable to the motherboard as well as the long power plug.
You will see the 4 pin power slot fairly close to the heatsink.
Jumpers generally come already set.
Make sure you have seated everything correctly, take out the ram and when you put it back in hold your fingers under the mobo, there may not be enough support under the ram slots therefore the mobo will bow and sometimes the middle of the ram will not be touching the slots.
Hope this works.
Dec 04, 2007 | EliteGroup MB ECS N FORCE 410 C51G-M754...
Not powering up
Did the CPU and cooling fan come pre-installed or did you have to install it? Did you forget the separate 4 pin power connector from the power supply to the motherboard? Is the speaker hooked up and are there any beeps? Do all the fans spin up? Do you have a video card that requires additional power connection and forgot to connect it?
Jul 08, 2007 | Foxconn 661FX7MI-RS (661FX7MIS)...
Aspire X-Navigator ATX Mid-Tower Case Logo
67 people viewed this question
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
