Question about Hunter 27185 Remote Control
Trouble with hunter remote 27185
The fan works fine however the light works with the remote but it also comes on by itself
  • raidikonis Dec 07, 2008
    I have the same problem
  • Canuckfan Dec 26, 2008
    I also have this issue with the 27157. The fan comes on by itself?
The problem is most likely a interruption in power. I just e-mailed Hunter asking if I could stop this from happening since my fan is over the bed. Their reply is as follows... The light will come on after power is restored following an interruption. This is a design feature of the remote control and cannot be modified or adjusted. We apologize for the inconvenience.
If you have further questions, please phone us toll free at 888-830-1326. Our hours are from 7:00am-7:00pm (central) on weekdays and 8:00am-5:00pm on Saturdays. Any representative can assist you.
Posted on Jan 13, 2009
I have a Hunter Ceiling Fan Model No. 27185. I can control the fan with the remote but can not control the lights with the remote. is there some instructions on how to operate the system?
27185 is the model # of the remote. Check to make sure your light wires are connected at the light fixture & receiver. Also, make sure your dip settings are set on the same frequency. Lastly, push the light button & pull the chain on the light.
Oct 06, 2013 | Hunter Dryers
I have a Hunter fan with remote and the light flickers without coming on completely - and you can hear a clicking noise coming from the fan. The fan works and the bulbs and batteries were changed
The pins inside the remote could have been switched or the wiring inside the fan could have come loose. Check the wiring at the fan first. The vibrations of the fan could have worked the light conrol wire loose.
Oct 10, 2010 | Hunter 27185 Remote Control
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
Jul 09, 2010 | Hunter 27185 Remote Control
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter Remote Control # 27185
Do not use the factory default position in either fan. Double check the dip switches, and make sure they are the same for each individual receiver and remote.Different codes for each. Dip switches are the oppsite direction in the remote for some reason?
Jan 01, 2008 | Hunter 27185 Remote Control
Televison & Video Logo
674 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Henry  Thomas
Henry Thomas
Paul Bade
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
