Question about Motorola Mobility W375 Cellular Phone
Battery charger conncection
Sometimes the charger works and sometimes it does'nt. It is very sensitive. I think its the connector on the phone. The battery is brand new. When the charger is plugged into the phone, it only charges if its plugged in a certain way. Do I need a new phone?
  • 24 Answers
The connector or charging pot of mot w375 have 5 wire connetions ,which connects the charger to the phone . if the connections are unsoldered the phone won't charge propaly , just resolder the wire connections it will start to charge propaly
Posted on Dec 06, 2008
My sony xperia phone want charge
Could be a bad charger, bad cable, or a bad connection in the phone. Sometimes the usb connector in the phone has a little dust in it, Always make sure the connector is clean and does not have any debris in it.
Jan 17, 2015 | Sony Cell Phones
My nokia 7230 does not power on what can i do
if the battery is dead try charging with a different charger,or better still go to any phone shop in your local high st, see if they can pin point problem,im thinking battery but could be the handset, more info on what you have already tried would be helpful.
May 27, 2014 | HTC Desire Cell Phone
I am having 1203 not charging problem
Either battery is too old (replace), connector is damaged (repair), or charger cable or transformer is bad. (Replace) If connector is bad youll be better off buying a new phone. Sometimes cleaning the connector can temporarily fix the problem.
Nov 02, 2013 | Nokia 1100
Charger not supported when i try to charge my the above message shown. - if if move my slider up - down, phone become sw off. why?
First the charger you are using is not meant for that phone. You may have to try another thin pin charger. The issue of the phone going off can be as a result of a worn out slide flex/cable/fibre hence signal are not passed on to the screen. The phone doesn't go off. The screen only is off. Otherwise the phone is still on. Have the flex replaced by a qualified personnell since it is sensitive to statics.
Oct 04, 2011 | Nokia X3 Cell Phone
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
My phone won't charge. Like sometimes it does but only if you push the charger in really hard but that doesn't always work. Also it loses the charge really fast like within a few hours.
Sounds like a bad connector on the charger, pick up a new one and you might need a new battery. If phone is under 1 year warranty your carrier should replace both for you for free.
Jan 07, 2009 | Cell Phones
I have a problem with LG K800 (Choclate) phone. The phone does not seem to charge the battery. I have replaced the battery and also tried the batttery in another phone and that works. The phone also...
sometimes it happens that the connector where the charger knob connects disinguage from the circuit or a pin of them behave like that..
but first connect ur cell phone to the pc. if it charges with that.....
Sep 25, 2008 | LG Cell Phones
Motorola Mobility W375 Cellular Phone Logo
96 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
