Question about Dryers
I need a wiring diagarm for a whirlpool solid state mark II elecrrict clothes dryer, model number LHE 9800
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Posted on Feb 20, 2008
  • 67 Answers
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Posted on Oct 28, 2008
david04928
  • 102 Answers
SOURCE: whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Posted on Mar 16, 2009
  • 7 Answers
SOURCE: burning marks on clothes in dryer
how old is dryer. drive belt may be slipping. Unit may have a faulty control that allows element to superheat. You have a potential fire hazard. What type of clothes are getting the burn marks? Should they be dried in a dryer?
Posted on Jul 02, 2009
garing
  • 998 Answers
SOURCE: Whirlpool Dryer Leaves black marks on clothes
change drum seal
thumbs up
Posted on Aug 17, 2009
LHE 5800: timer not working and not heating up
Have the timer checked and the heating element.
Jan 26, 2013 | Whirlpool Dryers
Need repair manual for whirlpool LHE 4930 (old) to replace belt or find what other problem may be keeping the drum from turning
Type in Google search for the manual. if one exist it will be there. Just type in --manual for whirlpool LHE 4930 washer. 99.9 of anything printed is somewhere or can tell you where on Google search
May 31, 2012 | Whirlpool Dryers
Whirlpool Dryer
If you believe the felt is the problem, you can go to Sears.com and look up the replacement part via the Parts Direct section. You will need the Model number which if you open the door, it should be a label on the body of the door frame. Using the model number you can look up the parts diagram for your Dryer. Hope this helps a little.
Jul 15, 2009 | Whirlpool ET8CHEXSQ Dryer
Model # LHE 7800 W1 On the thermostat by the heating element Which terminal does the red wire go on?
On a/c voltage , if you have 2 terminals on a part , it won't matter which terminal the wire goes on . There are several red wires in that area ,so if it goes to the thermostat , it doesn't matter which terminal on the thermostat it goes on .
Jul 13, 2009 | Whirlpool Dryers
Model LHE 6400- the dryer does not tumble but the
Normal 0 Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Jun 13, 2009 | Whirlpool LER7646E Dryer
Brown streaks of clothing from dryer
Check your front and rear felt seals. How old is the dryer and what is the model number?
Eric
May 16, 2009 | Whirlpool LER4634J Electric Dryer
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Clothes dryer doesn't spin
The way most domestic clothes dryers are made, it's usually hard to determine that the heating part works without the drum turning.
But, chances are, the drum belt is broken.
Please give the specific model number of your unit for a more complete response.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
Jan 23, 2008 | Dryers
Dryers Logo
Top Dryers Experts
