LImit Switch on AC/Heater Unit for Home
We bought our house about a year ago, and joined the smart AC program with PGE. Our Heater worked fine until after a new thermostat (their smart AC one) was installed. Whether or not, it is linked, I don't know. But now our limit switch on our AC/Heater Unit locks and cold air is blown through our house in the winter time. The only way to stop this from happening until the limit switch can be reset by climbing on the roof to the unit, is to shut off the breaker to it.
My questions is, how hard would this be to fix on our own, and if it would be impossible, how much would a technician run to fix it for us. We know we cannot afford a new heater/AC unit at this time.
  • Danny Clark
    Danny Clark May 11, 2010
    have you checked your filters to see if they're dirty/clogged?
  • 85 Answers
Get a diagnostic fee only, then determine if you can fix it yourself or not. Generaly you should only pay around 65. Depends on your service tech, call around. meBNme is on to something check your filters, if the unit is suffering from any air restrictions, it could be going off on high pressure. You could also be overcharged and or overcharged (from a leak).
Posted on Dec 06, 2008
Why is the dometic hot water heater not heating with 110 ac
This is assuming you have a 110vac unit. Could be breaker tripped in house, or high limit thermostat tripped on water heater, but most likely a burnt out element.
May 25, 2014 | Water Heaters
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Electric hot water heater gives lukewarm water
replace upper thermostat and hi limit switch. These are usualy made in one piece. On a two element heater, only one element comes on at a time
Dec 25, 2009 | Water Heaters
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Induction Motor continues to run.
pull the rubber hose off the pressure switch. and blow into the Induced draft motor housing if you cant you can pull the hose off the IDM and try to clear it with a small paper clip. reconnect and try again. you can also get the flash code off the board while the unit is running but not working.
Dec 11, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
240 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
