Question about Home
Broken showerhead clampwaterpick .
Shower head holding clamp is broken,locatednear where the hose connect to the water supply.can i purchase a new one? WATER PICK.shower massager
    Problem Solver:
  • 18 Answers
Yes it can be replaced. You can usually find either OEM or aftermarket that will fit your spray wand at your local home repair center or if you want OEM you can check with a kitchen and bath dealer or plumbing supply store but it might have to be ordered for specific model if not stocked.
Posted on Dec 11, 2008
How do I take apart a moen shower head?
You can remove the head from the shower arm by taking a crescent wrench. Put it on the flat sides of the nut on the showerhead and unscrew it counterclockwise. There is no way to take apart the Moen showerhead. If the reason you want to disassemble the showerhead is to clean it because it is clogged, disassembly is not needed. Just fill a Ziploc bag with a 50-50 solution of vinegar and warm water. Place the bag onto your shower head so it is fully immersed in the solution. Use a rubber band to hold it in place. Let it soak overnight and then take a toothbrush to any of the white scaly matter that might remain.
Aug 10, 2015 | Moen Home
Descale a showerhead
  1. What to do
    1. Unscrew the head of the shower from the hose. This may be quite stiff. ...
    2. If it is possible, unscrew the rose attachment from the shower head. ...
    3. Soak the parts in the descaling agent or white vinegar overnight. ...
    4. Reassemble the parts, checking that the rubber washer for the hose is in place.
Descaling shower head
Jul 21, 2015 | Water Water Heaters
Water does not come from the shower head
If your showre head has an external adjustment (usually on the face of the head) make sure that it is opened. Shower saver type valves have a push button on the pipe from the wall to the showerhead, usually close to or are a part of the showerhead. Make sure that it is opened, if you have one. Once done, remove the shower head and turn the water on. If you get water, look into the shower head. Most come with a water restrictor and it can come out of position and block the passage of water. The restrictors can vary in appearance, but usually they consist of a rubber washer and plastic disc, and are in the back of the showerhead where it unscrews from the piping from the wall. If you can get water without the shower head on, but no water through the showerhead, you can take it apart and look for restrictions or just replace it. If you cannot get water after all that, the problem is in your faucet or piping. Most Delta single handled faucets that I'm familiar with have a spring and cup washer valving arrangement. Those equipped with scald gard are somewhat more difficult to work on. Parts are available from H/Depot, Lowe's and similar. Hopefully the problem is in the showerhead proper, and not in the valve.
Best 'o luck, --W/D--
Jul 24, 2009 | Delta & Single Handle Shower Faucet
Hours after I take a shower, the showerhead will start dribbing
No, the showerhead is probably OK. My guess is that the head is relatively level, and the design of the nozzle allows water to pool inside. When you take a hot shower and turn the shower off, it begins to cool. As the shower head cools, a slight vacuum is formed, pulling air up into the showerhead. As you reach equilibrium, water is allowed to discharge as a dribble. This continues until the water has all been displaced. The fix for this is to turn the showerhead to the side, allowing the water to drain more quickly, and allow the air in. Try it.
Best regards, --W/D--
Jul 21, 2009 | Moen Showhouse S112BN Waterhill 10...
The shower head is clogged how do I clean it?
get some CLR which is calcium lime and rust remover.Unscrew it from the pipe on the wall with the water off and pour it where the water flows into the head and wait for it to drip out the jets.
Apr 21, 2009 | Grohe 28 783 000 Rainshower Jumbo...
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Water pressure drops after a few seconds to almost nothing...
In the hand held shower head where the hose attaches to shower head. In the head there could be a flow restrictor. It may be rubber or plastic. In some cases you can remove it, or check if something is blocking it. Also try running the shower without the head on to see if there is some debris in the hose, and to check your water flow.
Jan 29, 2009 | Water Pik Waterpik& Elements& Handheld...
Home Logo
171 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
