Keypad spill on Acer Aspire 3613 Laptop
I have an Acer Aspire which I had spilled pop on. The key pads press down fine, but it's like the computer won't recognize them. Nothing shows when they are press. can I remove the keypad or how *** i do this fix myself?/ thanks so very much.
More than likely the pop has gotten inside your unit. you would have to open the unit, disconnect your keyboard, clean the leads and connectors to the keyboard. If the unit was on when this happened the mb may have shorted in which you would need a new kb.
Posted on Dec 06, 2008
My acer travelmate 2410 the letters I o p j k l are typing the numbers 1 to 6 Instead
Has anyone spilled any liquid onto the keyboard?
This is a common indicator as to why the keyboard gives wrong character inputs.
If this is the problem, the keyboard will need replacing
If this is not the case try pressing the FN and NUMlock keys together
Jul 25, 2011 | Acer Computers & Internet
Acer aspire 4520 keys a, 1, s dont respond on laptop along with a few more.
sounds like you will need a new keypad, afraid theres no way to fix them, by any chance did you spill anything on the keypad as i have done this far to often with same problem arising.
May 27, 2010 | Acer Aspire 4520-5582 Notebook
Spilled pop on laptop now completely dead
YEP! Walk away from the laptop. You killed it! And it will be costly to fix!
Estimate that at least a keyboard, and probably a motherboard will have to be replaced. That is almost the whole computer. Better bet- buy a new Toshiba Toughbook - that is practically impervious to the spilled drink. But expensive!
Sep 22, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Feb 01, 2009 | Acer Aspire 3000 Notebook
Spilled pop on laptop Acer Aspire
well.. i dont think that this keyboard will ever work...
You need to replace the keyboard..... and for this you may need to contact any technical person.
regards,
Dec 06, 2008 | Compaq Presario 700 470024-192 Notebook
Keypad
nothing much you can do at this point. appearanly the printed ckt under neath the keyboard has a short.
did you spill some thing on the key board before???
try to see if there is something stuck under neath the keys.
other than that you need ot replace the keyboard.
Oct 25, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Sticky keyboard
You can carefully take off the keys and pop them back on. Use alcohol to wipe up any stickiness.
G'luck
Oct 24, 2008 | Acer Aspire 5100 Notebook
Acer laptop
Pop the enter key off (be gentle), then take a Q-tip with alcohol (rubbing not drinking) and clean the connector and the rubber riser. If the problem persists, the you will have to replace the keyboard.
Jun 30, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Jan 03, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
