Question about SanDisk Sansa e250 MP3 Player
Trying to add songs to my Sansa E250
When I plug my MP3 into my computer Rhapsody starts scanning information. For some reason it is going past 6000 items and then crashes. I have had this MP3 for several years and have not had this problem until recently when I tried adding a couple of songs to it.
Currently I show 720.5 MB used on my unit. What are the 6000+ items Rhapsody is referring to?
  • Anonymous Dec 29, 2008
    it wont play songs
  • 8,596 Answers
Time to reformat the device
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
I cant delete any songs
The e200 series players have 2 versions, plus a Rhapsody version.
How to check your version:
On the player
1. Go to the Main Menu
2. Select Settings
3. Select Info
4. Check the firmware version, if it says
v1 it is a version 1
( or Rhapsody
Rhapsody also supports Rhapsody service and channels
USB mode is Rhapsody/PlaysForSure instead of MSC/MTP for
the normal v1
Rhapsody fonts are smooth, antialiased )
v3 it is a version 2
Having a version 2 player, songs can be deleted on the player itself:
1. In playback mode, press submenu.
2. Select the Delete Song item.
For all versions you can delete songs:
1. Making a connection to a computer first.
2. Use the Windows explorer on the computer:
Select "My Computer" on the desktop and go to the internal memory or expansion card of the e250:
Go into the MUSIC folder. Select your songs inside the MUSIC folder and select delete.
Need more information ? Just post a comment.
Dec 31, 2009 | SanDisk Sansa e250 MP3 Player
HOW CAN I SYNC MUSIC TO MY SANSA E250..?
To sync music you have to first open the Rhapsody music player (If you don't have Rhapsody you have to download it fom the Sansa disk or you cannot add music). From there you can drag the songs you want from your library onto the icon in the list on the left that says "Sansa e250". On that screen there is a bar at the bottom that tells you how much space is left on your Sansa.
Hope this helps!
Jun 05, 2009 | SanDisk Sansa e250 MP3 Player
CHARGING A 1 DAY USED SANDISK SANSA MP3 4G
Run the Sansa Recovery Tool from Sandisks' website and start over from scratch. Usually this problem is caused by trying to transfer too many songs at once, but any number of Rhapsody errors could have caused this.
-Tha Mp3 Doctor
Nov 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
WONT DELETE!!!!
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 keeps freezing
If you're checking that its empty in your rhapsody program, you might want to click on My Computer and then click on your Sansa mp3 player and then go into music files and delete everything. If u want to delete everything, including videos and pictures, you can go into your rhapsody account, plug in your mp3 player and right click, scroll down and click on "format" this will hopefully delete everything on your mp3 player...if u don't apply to any of these, well....sorry i don't know how to help.
Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
Skipping tracks
Well you can go to the music folder for you mp3 player (just go to my computer and click on the sansa thing) and then delete off the songs that don't work and add them again.
Aug 10, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 getting worse since "upgrade"
Format your player and re-transfer your songs. The best way to format the player is by changing the player to MSC, then connect it to your computer and open My Computer and right-click and format the player remove the quick format then click start. :D
Jun 11, 2007 | SanDisk Sansa e250 MP3 Player
Songs not showing up
Renew Rhapsody sub and resync
Apr 23, 2007 | SanDisk Sansa e250 MP3 Player
Sansa problem
Jan 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
