Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a whirlpool side by side model#ED2GHGXMQOO.this morning it started making a horrible noise,it sounds like it is coming from close to the water filter cartridge at bottom of fridge .I took off the grating in front but cant see anything that would be making noise.At present time I have fridge shutoff because I cant stand the noise
  • 3 Answers
If it has an ice maker, the motor may be going out, so to find out, isolate the issue. Although first disconnect for 24 hrs. so to melt any frost away from moving parts; I believe you already have that covered. If still an issue, first re-disconnecting the power source, going to the back, removing any covering, finding the power source for the ice/water mechanism (usually on the right side or opposite the compressor), regardless it can't be missed. Disconnect the ice maker, and if the noise is gone, there you go. Reorder and replace the ice maker motor; a common issue due to constant use.
Posted on Dec 07, 2008
My ice maker makes a lot of noise at night I wake hearing it making ice droping sounds. I don't use a lot of ice can I turn the infrared receiving switch to off?
The noise is probably ice dropping into the pan and the normal ice maker and water valve sounds associated with making ice. Most Whirlpool models have a slide cover to "turn off" the ice maker - closing this cover fools the control into thinking the bin is full. Your owner's manual should provide greater detail on this option.
Sep 13, 2014 | Whirlpool Refrigerators
Frigidaire front load washe makes an awful noise when water starts to drain
Yes normally remove the bottom panel and the pump is in the front on the right side. Some companies recommend you clean it every few months. Also some will let out water when you open it up, so have a towel ready.
Apr 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
My 2008 bmw 535i sport has excessive noise from the door jams on both driver and passenger side. Sounds like a crinking stair at starts and stops. Also the moon roof has excessive noise and appears to be...
I have the same make and model. I have the noise on the driver side and it's the blinker. It comes apart for some reason and it's not visible to the naked eye, I'm having it replaced next week. Also, there is a problem w/ this series that will cause your car not to start in the morning. BMW is aware of this problem, but haven't informed any of us that paid $60,000 for this model. I suggest you talk to your local dealer, and perhaps buy a Mercedes next time! Hope this helps.
Aug 09, 2010 | 2008 BMW 535i Sedan
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Sub zero making a horrible noise
if it is coming from under your unit is it most likely the water inlet valve for the icemaker check that and let me know you will have to remve the 2 screw on the kick plate to get to it,it should be on the left side
Apr 07, 2008 | Refrigerators
Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Dec 28, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
