I have an Intermatic H-D Digital 7 Day Wall Switch Timer SS7C and don't have the instructions for setting it. Where can I find an instruction booklet or find help?
  • 30 Answers
Http://www.smarthome.com/2509/Heavy-Duty-Digital-7-Day-Timer-Switch/p.aspx
just scroll down, has quick start and setup manuals many languages
Posted on Dec 06, 2008
I need to program Intermatic EI20C in-Wall digital 7 day programable timer 20A 24-277 volt- white
The sell sheet shows Ei20 is same as SS7C timer
http://waterheatertimer.org/pdf/In-wall-timers-brochure.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#SS8
Open following link to check if this manual applies to your timer
http://waterheatertimer.org/pdf/Intermatic-SS7C-7day.pdf
http://www.beverlyhillselectric.com/ss7c.html
If you own this timer, check the programming details and add a comment and say if this manual applies.
If you are looking for a manual to post on your website, I would guess this manual is 99% chance of being correct.
If you need someone to explain the manual, please add a comment and say which part of manual is confusing, and I will respond. OR take advantage of fixya live assistance and expert will speak with you via phone while you program the timer.
Sep 29, 2011 | Hardware & Accessories
I can't download the instruction manual from Intermatic's website. I have a EJ500C timer and want to know why they caution against using it with CFL's and how to program it to shut off...
EJ500 7-day or astronomic timer is incandescent light bulb timer.
Different timers have different Load ratings.
Intermatic ST01C timer can control CFLs.
Aube timers have same wiring capability as Intermatic, and offer CLF control, but you have to choose either astronomic timer, or 7-day timer.
Open following links for manual and timer information.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
http://waterheatertimer.org/Aube-timers.html
Jul 16, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
Display reads noOp and cannot manually switch off light. Temperature is not cold. New battery installed. Instruction sheet says timer needs repair. How do I fix it? Thanks.
Remove the timer from the wall box. Make sure that a fresh battery is in the timer, then tap the timer against something rather gently while pressing the on/off button. I just did that with three timers I had in storage. Clean the battery contacts too. Intermatic SS8
Sep 25, 2010 | Intermatic E-Z SET DIGITAL TIMER - SS7C
Computers & Internet Logo
96 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
