Question about Casio Baby-G BG169-2V Wrist Watch
When I press light buttopn in the middle the display goes blank
Don't think it is the same watch as listed but is a baby G watch. When press light button in the middle the display goes blank no light is displayed.
  • blckparade Jan 25, 2009
    I had the battery replaced on my wife's BG169WH and afterwards the when I press the light button in the middle, the light no longer lights up. The weird thing is that when I press the "reverse" button in the upper right hand corner of the watch, then the light light's up?
    Is there anyway to reset this back to normal?
    Problem Solver:
  • 5 Answers
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
Posted on Dec 11, 2008
The screen goes blank
Clear sign for a battery replacement as soon as possible.
Apr 27, 2016 | Casio Watches
Casio pathfinder battery operated watch keeps blanking out display?
Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
For more information, you can download the manual of your watch here (direct download link):
Timepieces Watches Manuals CASIO
Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
Umbro watch instructions
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu:Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Jul 15, 2013 | Watches
Starck PH1110 display
In some watches, opening the case causes battery power to be removed and the display goes blank, The display should return when the battery case is installed correctly
Mar 14, 2013 | STARCK Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
    Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
    hope this helps :)
    Apr 09, 2011 | Nixon Lodown Tide watch
    My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
    From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
    Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
    I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
    Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
  • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
  • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    Casio WV300da ( #3023) won't get atomic time
    The manual mode rarely works, because you have to be awake to do it and most of the time the best signals are from 1am to 3am in the morning.
    Dec 13, 2017 | Casio Waveceptor Atomic SilverTone...
    Casio Baby-G BG169-2V Wrist Watch Logo
    500 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
