Question about Datalogic D100 Handheld
Beeps instead of reading the barcode
This is at a library for scanning the books, it seems to be only beepeing instead of reading the barcode
  • 3 Answers
Hi Richiet Seems liek it has not been detected into the system or has gone faulty. I would first wonder is ot a new item ? If so try reinstanning it on the system you are using, If it was an older item do the same but maybe look atthe fact that it could be faulty in both instances. YOu always have a warrenty with manufacture and by law they will have to give you full technical support on the item
Posted on Mar 09, 2007
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Apr 14, 2009 | Symbol LS2208-7AZK0100S Handheld
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
Scanner beeps. Laser is a dot instead of a line.
There is a problem with the scan engine. The dot is created when the mirror inside the scan engine stops oscillating. If your scanner is still under warranty send it back for repair or request a replacement.
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Double beeping
Usually Barcode devices come with a code book to program them, This is usually contained in the user manual, and will be several pages of barcodes, using these barcodes you can set the options of your handheld device, including what types of barcodes it can read and other options like output formats and seperator characters, you should also be able to change whether it beeps or not,
Jul 05, 2007 | Metrologic Instruments MS9535 VoyagerBT...
Datalogic D100 Handheld Logo
453 people viewed this question
Top Datalogic Computers & Internet Experts
Paul Bade
jackcity
jackcity
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
