Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series clothes dryer
shared by 3 users
posted by ksjrsm on Feb 15, 2007
My dryer runs for a few minutes and then shuts off. I can turn it on right away, it is not overheating.
Sometimes it runs for 2 or 3 minutes and sometimes 15 minutes before it shut off.
Can you help me ?
Thanks, Shirley
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by snowwhos on Feb 25, 2008
I seem to have the same problem, model# 110.66722694 It will run for about 15 min then shut off. I can restart it just fine but will shut off 15 min later. I disconected the flo pipe and same result. Any hints to fix this?
Posted by JayHenry on Feb 20, 2008
on a 70 series kenmore
the heat element is not heating up but also it seems that this problem started when the timer started not shutting off as well what is the problems and what parts do i need to fix it.
Best Solution
posted on Aug 12, 2007
Helpful (85)
troylove11
Rank:Wiz Wiz
Rating: 85%, 1147 votes
It possiblly a timer going bad.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on kenmore 70 series clothes dryer:
I don't want to Accept this solution
Can you Help with these Dryers problems?
Dryers
it heats but doesn't rotate.
Dryers
it heats, but the drum doesnt turn. dear husband has it...
Dryers
Rivet gun needs put back together. rivet was stuck in gun...
The control knob no longer turns while the dryer is...
the timer works and i know the dryer is getting power,i...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
