Question about HP Compaq Presario R4000 Notebook
Display brightness I just fixed the power problem. The battery now charges fully. Odd thing... In the past when ever I work off the battery, the screen dimmed to save on power. But when the power was on, the screen would brighten... Now, the screen is dim when the power supply is in... and it brighten when it runs on battery. Which drains the battery way to fast...How'd this get switched? my screen brightness alternates between bright and dim, when my battery is charging on a/c or when the battery is fully charged
  • 50 Answers
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Posted on Dec 07, 2008
On the ride the battery gets drained of power. When the battery loses power the bike loses revs. Is this the regulator and how do I test it or is there something else to check?
Same thing happened to me. It turned out to be a corroded connection from the alternator that snapped off when inspected. The first thing to check is battery condition. A fully charged battery should be around 12.5 volts. When the engine is running the voltage should increase to around 14.5 volts. If it does increase then your charging system is working as it should and the problem lies elsewhere (possibly a battery that is past its best and needs replacing). If it doesn't increase the voltage, then chec the wires from your alternator (ther should be 2 wires) and follow these to the junction connector. This was where mine was badly corroded. I used more cable to bypass this connection and my problem was fixed. I then replaced the connections with new ones and all is fine. The bright yellow straw is pointing to the corrosion problem. Hope this is of help as totally replacing your alternator isn't cheap.
Mar 11, 2015 | Power Motorcycles
Tip
12 Most Essential Tips To Save, Improve & Extend Battery Life
Have you ever faced the situation where you are in hurry and suddenly your battery goes down? I think everybody have gone through such a kind of situation. So it's the time to think on what can you do to not to stuck in such a situations? How to get rid of this problem? How to increase the performance of your gadget battery? Learn how to extend and improve the battery life.
In last posts under the topics of Android, we have seen how to track lost mobile phone and how to solve display flickering error, but today we are going to focus on battery issues, because as long as our device is running smoothly we are gonna work smoothly. Not only proper charging is essential for preserving the health of battery but taking care of battery does more work to save it much longer than we thought. As we know, today we have devices which are comes with Li-ion and lithium polymer batteries but as time goes these rechargeable batteries loses their capacity.
Here we goes, we've got the ultimate guide on how to extend and improve battery life. Try these tips to extend your battery capacity. See what's sucking the most juice. And try to get out of battery problems. Not only tips but also we are here to provide you the instruction to change the settings for improving battery life.
Just follow these tips as shown below...
1. Proper charging:
First and most important thing, try to avoid using your device till the battery falls down below 10% and prevent it to go fully discharge.
2. Change the screen brightness:
Brightness of the screen is the next most affecting factor for battery drain. As long as the screen is ON and with higher brightness; the faster your battery goes down. So change the screen brightness as low as you can stand it and still read a text. Moreover set the locking period as quick as possible. As quick as it gets shut down, the more power you save.
3. Avoid over charging of phone when it got fully charged:
First don't use phone while charging and don't keep your device charging once it got fully charged. Moreover don't forget to plug-in your device to charge, when the battery falls bellow10%.
Read More: http://www.problogbooster.com/2015/07/most-essential-tips-to-save-improve-extend-battery-life.html
Reff.:
12 Most Essential Tips To Save Improve Extend Battery Life
on Jul 06, 2015 | Android Apps
I've got a hitachi 2nd fix nail gun and for some
First thing is , when did You clean it last?
Sep 30, 2014 | Tools & Hardware - Others
While switched on the phone screen has gone black/blank. Battery is fully charged. Nothing is working.
may be the display of the phone is damaged or the power cable to display is slipped. Contact your nearest service provider to get the things fixed
Dec 29, 2010 | Nokia Cell Phones
Sometimes when i try to take a picture - the camera won't let me - a flashing hand appears on the display screen and it won't let me take the picture - i have the camera on auto adjustment - i just want to...
If it is set to auto then about all I can think of is low light pictures and you may have the flash disabled or the battery level is too low to power the flash .
Try taking a picture in bright sunlight and see if it behaves. I can't recal if that model disables and enables the flash with the menu or if it has a button on the case looks like a lightening flash. And don't forget to charge your battery
Apr 12, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Back light fine with power supply and goes off on battery.
I would need to know what operating system you are running because Vista has a setting for the display brightness when running on batteries. I would suspect that, that setting is turned down to conserve battery power. If this is not the case, then the battery may be too weak to put out the correct voltage requirements for the display. If you have Vista, go to the control panel > power options > In the left pane, look for the display brightness > here you can change the brightness for running on battery and for AC power.
Oct 14, 2009 | Dell Inspiron 1720 Notebook
Canon 1000d display blank when power on,battery charge full
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Display brightness
That poroblem comes from your Motherboard and there are some trasistor that we be remove and resold anotherone where did you stay because this will be feine to an engineer to sit down and tackle the problem
ok
Rata this solutio
Aug 30, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
472 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
