Question about Emerson MW8102SS 1100 Watts Microwave Oven
Light bulb burned out
Light inside of micro burned out this morning while re-heating a cup of coffee. Is it replaceable, if so where do I get it and how do I do it?
  • Emerson Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Dec 07, 2008
I have a Jenn air micro wave and I attempted to heat up a cup of coffee in a plastic cup and forgot about it when I smelled something burning I discovered that the cup had melted and the microwave had
Take a lemon and slice it. Put it in a ceramic bowl of water. Set the timer for 10 minutes. Leave for an hour and then wipe the inside with a clean cloth. It will get ride of the smell, if that was your question? It the cup has stuck to the turntable, set microwave for 1 minutes and scrape the cup off with a paint scraper.
Dec 02, 2016 | In Microwave Ovens
The inside light bulb that works when the door opens and food is cooking is burned out, I have the new bulb but don't know where to replace it.
Brand and model would help but I'll guess at this. If micro is a wall hung unit over the range, you usually need to remove the top grill assembly above the door. Then look inside directly above the area where the bulb is located. You should see a metal cover with usually 1 screw in it to remove. Once screw is out that metal plate usually pulls forward and upward to reveal the bulb and socket. Replace bulb and reverse procedure to assemble.
If the micro is a counter top model---the complete outer case usually needs removed if you don't see a small access door by the bulb. Remove all screws around back edge and any screws in the side panels---then lift back edge and pull outer case rearward to remove.
Jun 03, 2015 | Microwave Ovens
I made popcorn last night and my microwave worked perfectly. This morning it will not heat a cup of coffee. What's up with that? What can I do to fix it. It is part of a matching set. Kitchenaid micro over...
When unplugging it for half a minute or so (this should reset all settings) won't help, it must be defect. When you are convinced you did press the right buttons and you are in the correct program you don't need to unplug. But for that you have to be sure it is not switched to oven. In 30 seconds it won't be warm enough to heat your coffee
Mar 10, 2015 | KitchenAid Microwave Ovens
Mcc1010t magic chef micro/convection
follow this steps and fix it. God bless you
If the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Jul 13, 2013 | Microwave Ovens
Need to replace light bulb inside ge sca1000 microwave
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 15, 2011 | GE Microwave Ovens
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
CUP HANDLES GET TO HOT WHEN I WARM COFFEE.
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Nov 30, 2008 | Maytag Microwave Ovens
Emerson MW8102SS 1100 Watts Microwave Oven Logo
59 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
