LG DVD/VCR Combo Slow rewind FF problemsimes it just
Recently my vcr started only rewinding/ff very slowly. Sometimes it won't even rewind and just ejects (same with playing). Its an LG DVD/VCR combo Model V9822W
Any ideas?
  • simmyf Dec 07, 2008
    Forgot to mention that when it ejects frequently the tape is not fully rewound into the tape case
5 Suggested Answers
dodgecharger
  • 254 Answers
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Posted on Jul 10, 2007
Shuttle83
  • 1139 Answers
SOURCE: Sony DVD/vcr combo stops
This is an indication that the tape sensors may be dirty or going bad. It could also be due to tape tension (the lack of). Do you have the service documents for this device?
Posted on Sep 22, 2007
ANTHONYPAULB
  • 17 Answers
SOURCE: Funi vcr combi
theres probably something out of whack in the vcr probably one of the pins inside your best best if you want to keep it is to take it to a repair shop or if your handy open it up and see if anything is either stuck in there or bent.
Posted on Nov 30, 2007
  • 979 Answers
SOURCE: Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Posted on Feb 15, 2008
SOURCE: my vcr says SAFE how do i get it back into recording mode?
went to RCA site and found manual for my vcr- thank you
Posted on Feb 05, 2009
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
GE VG4270 vcr power turns off quickly when recording or playing a tape
Have someone look inside---if tape is not loading all the way against the video heads or tape does not move in play-rewind-FF then there is a problem with the transport mechanism which is what performs these functions.
May 13, 2012 | GE VG4270 VHS VCR
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
Apr 22, 2010 | JVC HR-J461MS VHS VCR
My vcr says SAFE how do i get it back into recording mode?
Feb 02, 2009 | RCA VR355 VHS VCR
VCR is in locked position when play is pressed.
I believe Panasonic has taken over the service and distribution of Akai.  A check on the Internet for Akai will lead you to a service link. I have an Akai combo TV-VCR that I was able to download a manual for. Parts.com may have other parts for your unit. I need more info on your unit. Does it run in play? Rewind and FF? Does the counter move? If the unit functions mechanically, be sure your patch cords are properly connected - yellow for composite video, white and red for audio. Be sure the input is properly selected on you monitor or TV.
Nov 28, 2008 | Televison & Video
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Feb 15, 2008 | Televison & Video
VCR won't rewind
Soution #1 get nice but cheep VHS " rewind " macine.
2nd. Some machines have a special rubber wheel in the center,between the left [ take up or rewind ] & right [ play\record ] assemble. VERY diffiult to repair if u don't know what u are doing.
3rd. Find & REplace EVERY rubber band that u find in the machine.
Oct 18, 2007 | Sansui VHF6010 VHS VCR
VR8707 VCR. No Rewind or Fast Forward
I thing that you are having problems with your gear assembly on the carriage. FF and RW use a series of gears to move the tape from one reel to the other. If possible could you take some pictures of the gear assembly. More then likely the gears are not making contact or the drive belt has slipped. Granted this is just conjecture until I can see those pictures of the assembly. electronagetec@aim.com
Sep 10, 2007 | Samsung VR8707 VHS VCR
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
