Question about Dryers
Amana dryer-can't get to belt
How can I get to the belt? Don't see where it is accessible through the back
Cousar
Posted on Dec 06, 2008
I need to change the roller that is connected to the belt. Is there an easy way to access it from the back.
You get the front panel off and work from the front on these. It ain't very hard. You remove 2 screws from the base. themobilian_476.jpgyou gotta remove the tub. I have an Amana dryer manual here
Dec 17, 2010 | Amana NDE5800AY Electric Dryer
How do I get the belt off my dryer drum
If access is through the back or front, push tensioner towards the drum and pull belt of the motor pulley.
Jul 01, 2009 | Amana NDE2330AY Electric Dryer
Gas dryer won't start
REMOVE YOUR ACCESS PANEL AND SEE IF YOU HAVE A BROKEN BELT IF NOT REPOST. ACCESS PANEL LOOKS LIKE IT COMES OF BY 2 SCREWS AND RAISING IT UP AND OFF.
Apr 17, 2009 | Amana ALG331RAW Gas Dryer
How to install drum belt in Amana Model LED20AW. This model does not have front or back panels to remove. Fabio
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
I HAVE AN AMANA GAS DRYER THAT MAKES A VERY LOUD
Here is the link for the owner's manual, but it doesn't look like much help. Just cut and paste on the address bar of your browser. http://shop.amana.com/assets/pdfs/literature/40125301.PDF
Once you get through looking over the manual, here is how you fix your dryer:
  1. Unplug the power plug, disconnect the gas line, and vent hose, and pull out where you can access all sides.
  2. Take a putty knife and insert it between the top and the cabinet at the front corners to release the spring clips.
  3. Flip the top toward the back making sure the wiring harness to the timer and controls does not get pulled.
  4. Take off the access panel toward the bottom of the cabinet, push the belt tensioner away from the belt, and pull the belt off of the motor pulley.
  5. Lift the drum out of the cabinet, clean and re-grease the ball and socket at the back of the drum, clean off the surface where the belt rides with steel wool.
  6. If the idle rollers turn freely, clean the lint off of the surfaces, put the new belt on the drum and lower back into place.
  7. Put the belt back on the motor pulley, put the bottom cover back on, flip the lid closed, reconnect the gas, vent hose, and plug in.
If you found this solution helpful, please don't forget to rank it.
Mar 27, 2009 | Amana ALG331RAW Gas Dryer
Belt broke on Amana dryer
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Jan 29, 2009 | Amana ALE866SB Electric Dryer
Amana
Under front of dryer, there are two 5/16" machine screws which hold the kick plate on. Remove these for access.
Aug 12, 2008 | Amana ALE443RAW Gas Dryer
Opening up the dryer
Usually you can access the belt by uncovering the back panel or bottom end. Then you can access the belt. Good luck
Aug 07, 2007 | Amana DLE330RAW Electric Dryer
Dryers Logo
Top Dryers Experts
Richard Roth
Richard Roth
