Question about Microwave Ovens
Unit making loud noise
Turn table makes loud noise, is there a need to lube some part of moiro?
  • maxphoto Dec 06, 2008
    I have the same problem on a Hotpoint Space Maker Plus. I twisted the center turning knob a bit and it has stopped (for now).
  • William Miller
    William Miller May 11, 2010
    Lubrication is not recommended except in extreme cases.
    Where does the noise seem to be coming form?
    The turntable system?
    The stirrer (if equipped)?
    Please reply back with your brand and model number so we can help you.
    Genius:
  • 1,199 Answers
Your turning spindle must have warped due to high heat in oven
Posted on Dec 07, 2008
Making odd screeching noise,thought it might be the ac motor for turn table ,but it looks and sounds good because i took it out and hooked it up to ac power.
The loud sounds are always the sound of the magnetron failing. It may actually be caused by the capacitive reactance of the large capacitor drying up.
Nov 24, 2013 | Magic Chef MCD1611ST Microwave Oven
Frigidaire FMV145K 950 Watts Microwave Oven makes LOUD noise when turn table turns?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 25, 2011 | Frigidaire FMV145K Microwave Oven
My oven makes a humming noise when it is running - either in heat mode or defrost mode. The noise goes from nothing to loud, then loud, then it quits. The microwave is only 2 months old and it has been...
No! this not normal and should be checked out right away, the problem could be in the high voltage transformer being loaded down by the magnetron, or possibly the turn table motor. The warranty must still be in place and I encourage you to take at vantage of it.
Jan 14, 2011 | Maytag UMC5200BA Microwave Oven
Ge above range microwave, when it is turned on it makes a rattili
is this noise a loud noise or low. and tell me the make and what the model. please
Mar 20, 2009 | Goldstar MV-1501 Microwave Oven
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Loud noise coming from turn table
I have the same problem my microwave is a kenmore this is the second one I've had and they both did it I solved the problem by re-seating the turn table however if you are skilled at taking things apart you can put a few drops of small motor lubricant on the spline it worked for me. good luck!
Nov 21, 2008 | Microwave Ovens
Microwave makes a loud noise while using.
Could you describe the noise?
It may be a noisy fan motor or a failing magnetron or high-voltage transformer.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 13, 2007 | Microwave Ovens
Microwave Ovens Logo
95 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
