Question about ElectroVoice RE-1 UHF Wireless Handheld CSR1000 Reciever and CSH1000 Handheld Transmitter
Buzzing noize I have a R200 UHF wireless microphone system used for my violin, the problem that i am getting is that when i connect the wireless sysytem to a main p.a. system i am getting a laoud buzzing noize coming through the speakers to the point were i am unable to use it whilst performing on stage. What can i do to avoid this problem?
Have you tried using a different power adaptor? I have noticed with mine that the as the original failed there was a noticeable hum, a new power supply (of reasonable quality) solved the problem.
Posted on Jul 25, 2007
Shure wireless guitar pack won't turn on
First, replace the battery. If that does not resolve the problem, call Shure Repairs at 800-516-2525.
Jun 10, 2012 | Shure PGX14 Guitar Wireless System (UHF)...
Should I run my guitar through the High z aux. Or the low z balanced for best results ?
I assume you are wanting to connect the output of the receiver into the input of your guitar amp. Use the 1/4" output on the receiver to the 1/4" input on your guitar amp.
Dec 23, 2010 | Shure PGX14 Guitar Wireless System (UHF)...
With the -10dB pad setting, still get distortion with loud singers using SLX Wireless Microphone. Need a mod to say -20dB pad. thanks
Yes I have this exact problem myself. Work for nightclub and our original Shure wireless was fine and we replaced it with an slx. We have MCs that really yell into the mic. I'm gonna try and find an older 58 capsule to pit on it and see how that goes. The mic would probally be fine with normal singers.
Oct 15, 2010 | Shure SLX-2 Handheld Wireless UHF...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Change the samson airline 77 microphone for a AMT, for sax player
Unfortunately, you don't have enough information to go on to give you a definative answer.
The Sampson Aireline will plug onto ANY xlr type DYNAMIC mic and should work.
The one thing on the AMT Elite I found said it was a "condenser" type element which means it would NOT work with your Sampson setup. Condenser mics require a Phantom power arrangement to charge the element and operate the local FET input amplifier.
If you are trying to mic a violin, the Airline 77 that was for the dynamic mics is a very poor choice as it is low impedance. Most violin pickups use a Piezo pickup which requires VERY high impedance input amplifier.
For my wife's violin we use an Autolycus pickup and an X2 wireless sytem. The pickup comes from New Zeeland and the X2 is CD quality digital wireless link. You have to make your own connector at the violin for the X2 cable was intended for guitars.
Dec 21, 2009 | AMT Datasouth Violin, Viola, & Mandolin...
I bought a pick up for my violin. But when I plug it in and play. I get a rubbing sound coming through the speakers, like the pick up is picking up the bow strokes rather than just the notes... Its sounds...
Yes, and it will pickup "handling noise" as well.
A hint I can offer is to try a mute. One of the bent wire ones with weights that clips over the strings in back of the bridge..
I have found a perfect match for my wife's violin. We use an Autolycus pickup and an X2 wireless link. NOTE: the piezo pickups require a VERY high impedance input amplifier. You MUST use a very short cord or all the highs get wiped out.
We got the Autolycus from the source in New Zeeland (about $70). The fellow has a website with a sound clip. Search Google for Autolycus violin and you should find it. Do listen to the sound clip. The little piezo clips on the top where the sound post is with a plastic clip that reaches through the treble side F hole.
I had to make my own cable for the X2 wireless as it has a TRS 1/8 connector and the signal is on the ring and the tip and sleeve are ground. The Autolycus comes with an RCA jack on a pigtail. The X2 has a very high impedance input at the transmitter which is ideal for the Autolycus pickup. We use a Berhinger ACX1000 acoustic amp. It actually sounds like a violin.
Use good quality strings is important. The X2 system is a digital transmission at near CD quality.
Oct 24, 2009 | Fishman V200 Professional Violin Pickup...
I testing out a Strawberry Blonde II amp with my violin using a Fishman V200 and Fishman GII preamp. I can't seem to get a good sound -- its picking up alot of bow noise and the sound is harsh and raspy....
I have found a good combination for my wife's violin. We are using an Autolycus pickup (from New Zeeland about $70... search Google) and the X2 wireless transmitter/receiver pair. The X2 has the extremely high impedance required by the piezo pickups. This pickup clips onto the top surface of the violin with a small plastic clip through the F hole on the treble side. It is easily moved between instruments.
The Autolycus is sold online and they have a demo there.
Of all the pickups we tried, this one "sounds like a violin" and many people have complemented us on the way the violin sounds. A sound man said of the setup, this is the first violin pickup and wireless he has not had to EQ to sound right.
I used an oscilloscope to verify the output waveform from the pickup matched the resulting output of the X2 receiver.
Note: I had to make my own cable for the pickup which has an RCA female and the original X2 cable supplied had a 1/4 inch male.
I got the X2 system through online ordering from MF. (They recentely had a special on them at $220. The wireless is really nice... no long cable to load down the piezo.
Sep 30, 2009 | Fishman V200 Professional Violin Pickup...
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
ElectroVoice RE-1 UHF Wireless Handheld CSR1000 Reciever and CSH1000 Handheld Transmitter Logo
131 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Steve Allison
Steve Allison
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
