Question about Microwave Ovens
Lost connection to techjuli - Microwave Ovens
    Novelist:
  • 157 Answers
Hey there, responded to your original post. lets finish here, ok?
Posted on Dec 06, 2008
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
My RV lot lost power and my Domestic microwave hasn't worked since then. Its model DOTR12 CBIV and I am located near Omaha NE. Can you help?
Check fuse box for blown fuse bad fuse or fire ants or other inscects or insects nest in fuse box also wiggle an inspect wire for Burns or loose connections
Aug 07, 2014 | Microwave Ovens
The door of the combination oven microwave slammed shut and the oven lost all power
check the main cable of mven maybe its Rupture test it if it give 220v ac or 110 vac
if it ok then check fuse bass wich the cable connect on it maybe it damaged
Nov 27, 2013 | Bosch Microwave Ovens
Techwood home subwoofer model psw112 fuse and fuse cap or holder
Unless the same type is found the fuse cannot be fixed into the holder. So it isbest to get this sample to the nearest electronic store and check out th ereplacement type availabe and if the alternative fits the provision.
Othere wise you can solder a fuse wire of the same rating internally to get the set connected.
Jan 07, 2012 | Microwave Ovens
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
Turns on but doesn't heat only a year old LG LRM1260SW 1200 Watts Microwave Oven
I have had the LG model lrm1260sw microwave for 3 years. Recently it quit heating. I found the problem was the soldered grounding lug connection on the power transformer had lost circuit continuity and failed. One of the secondary coils on the power transformer, red wire / bare copper wire, is connected to ground / chassis. I cleaned the lug connection and added a length of wire twisted together with the bare copper coil wire and soldered to the grounding lug. I then grounded the extra added length of wire to another chassis ground point. Make sure the transformer to chassis mounting screws are tight also. Now the microwave oven works like new again.
Feb 27, 2010 | LG LRM1260SW Microwave Oven
What would cause the control panel display to be very dim and almost unreadable? It is a Dacor microwave oven model DMO2420S
sorry i lost my connection
i am tracking down your part and will provide you with the part number as quickly as i can
i want to make sure i find you the cheap[est in cost as well
thank you
'again im sorry i got disconnected
Nov 01, 2009 | Microwave Ovens
Where do wires connect???
Black is neg, Red is pos, and White is neutral or ground.
Apr 30, 2009 | Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
